5F1 Champ - Weber Kit Build/Review
Discussion in 'Shock Brother's DIY Amps' started by jvande7, Oct 6, 2020.
  1. jvande7
    jvande7 TDPRI Member
    Oakland, CA
    UPDATE: This has less to do with Weber vs Mojo/others etc, and more to do with fine-tuning the 5F1 build/project itself.
    I calculated that my 6V6 was biased quite hot, and even though this is widely accepted nowadays in these single-ended Class-A Champ builds, I used four 5w 9v zener diodes on the PT CT ground to lower my B+ from 383v down to 350v and I like the results. Slightly less output, and slightly "better" overdrive/distortion. Now my 6V6 appears to be dissipating more like 12w instead of 14w+ based on some fast/loose calculations.
    Next I'm tinkering with the cathode bypass cap value on V1a, as well as choice of preamp tube. Currently using 10uf cap and a 5751 tube for a slightly more mellow/refined Champ, but I'll probably end up with NOS 12AX7 back in there down the road, as I want more of that classic Champ dirt. Just trying to dial out that boomy/farty parts a little bit. Might try a 4.7uf bypass cap next.
    Linkjr likes this.
  2. Lowerleftcoast
    california
    I think you should adjust for a dissipation of 14w+ for the Champ goodness.
    jvande7 likes this.
  3. jvande7
    Oakland, CA
    Only problem is I'm not sure I'm calculating correctly. I'm just a tinkerer, no formal training, and I've found several methods of calculating. Anyone care to chime in as to what I'm actually running here?
    NOS 6V6 (KEN-RAD)
    2: 3.36v
    3: 321v
    4: 303v
    7: 3.38v
    8: 18.25v
    470 ohm resistor (464 ohm actual)
    B+1 352v
  4. jvande7
    Oakland, CA
    Original voltages before zener diode mod were as follows...
    6V6
    2: 3.4v
    3: 356.5v
    4: 330v
    7: 3.4v
    8: 20.3v
    same 464 ohm resistor
    B+1 383v
  5. Cali Dude
    Cali Dude Tele-Afflicted
    California
    Very cool. I have great respect for you, and guys like you who have the talent and patience to complete such a project. Congrats on the nice finished product.
    jvande7 likes this.
  6. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    Agree. Especially with an efficient 12" speaker. I had one built by Modern Sound Amps a few years ago and it's my all-time favorite amp. VERY versatile. I went with a ceramic speaker as I was more interested in tube breakup than speaker breakup. It gives me plenty of clean headroom and roars when cranked. My builder put a switch in it that gives me the traditional early breakup or a higher clean headroom. I use it for everything from country, rockabilly and blues to worship to ambient and jazz. Fantastic amp with a tele!
    jman72 and jvande7 like this.
  7. archetype
    archetype Fiend of Leo's
    Williamsville NY
    CJ is awesome. He's a Weber encyclopedia and advice producer.
    jvande7 likes this.
  8. jvande7
    Oakland, CA
    Using the calculation method from this post https://www.tdpri.com/threads/5f1-6v6-bias.941913/#post-9019530
    My build/6V6 was originally dissipating 13.82w which is 115%
    and now it's at 11.19w which is 93.25%
    Maybe I'll "remove" one or two of those zener diodes by simply changing where the PT CT wire connects. See how that sounds.
  9. Nickfl
    Nickfl Friend of Leo's
    Your calculations look like they're right to me, but the 6v6 is not necessarily a 12 watt tube. Data sheets may list it as such but most people these days seem to agree that they really are 14 watt tubes with the possible exception of the current production tungsols which seem to be uncommonly fragile, and JJ 6v6 tubes which are structurally different and definitely capable of dissipating a good bit more than other makes.
    I think your original plate dissipation was probably about right although the voltages were maybe a bit higher than ideal. At the end of the day what really matters is which sounds better to you.
    jvande7 likes this.
  10. jvande7
    Oakland, CA
    Would it make more sense to change the value of the 470ohm cathode resistor on the 6V6? Most folks that have changed that value ended up changing it back to 470 (from all I've read in these forums).
    I'm probably obsessing over nothing and should have just left well enough alone haha
  11. Lowerleftcoast
    california
    What Nickfl said.
    Your observations of the lower B+ ended up with a more pleasing sound. I would try clipping in) paralleling a resistor with the 470R to see if a lower value cathode bias resistance will work. Of course you can clip a jumper across a diode or two to hear what that does as well.
    I agree with the 14W 6V6 rating.
    jvande7 likes this.
  12. Linkjr
    Linkjr Tele-Meister
    Uk
    I also lowered my 5f1 high B+ using zener diodes and the improvement is immense I kept the 470ohm resistor in
    My admittedly limited understanding is people change them to bias a hot tube due to too high b+ but since your voltages are reduced the 470 stock is fine.
