Wharfcreek
So I've been working on amps for decades now, and if there's any one thing I've learned, it's that some times the 'original' is as good as anything else!! Truth be told, some of those old amp designers of yester-year were pretty smart! But, the unfortunate reality of today's world is that a lot of what was easy to accomplish back in the day.....ain't so easy now! One big factor is 'tubes' alone......as we're all experiencing now with the sad things going on in the Ukraine!! But, there's more than just tubes involved in this. In looking at the 'pricing' of the subject amp, to build a 'replica' of a 5F1 Tweed Champ, complete with tubes, speaker, and cabinet, a guy's looking at a price tag of well over $500, if not closer to $600 or even $700, depending on how it's done! Buying the best of everything, including a tweed covered and 'aged' vintage clone cabinet which alone can be upwards of $300..... I don't think a $700 figure is an exaggeration!!
So, I've set out to try to figure out a way to make this a more affordable proposition for someone. In so doing, I think I might have 'strayed' perhaps a bit to far from the 'original' 5F1. That's my dilemma, and the real reason for this posting. The basic question here is: How far away from the 'original' amp design can one go, and still call it a 'Champ'?
Just to clarify, I believe one can build a legitimate 5F1 Champ on just about any kind of platform or 'chassis'. The schematic is out there for the masses to follow, and 'clone' parts are all over the place. So, a guy can grab a box, a couple of transformers, some sockets and passive parts, and within a day or so you can construct a 'clone' 5F1 that is pretty much spot-on as far as all the specs go for a 5F1 amp. BUT....what if you deviate in several areas? For example, in one of my early clone amps I migrated from a 5Y3 rectifier to a 6CA4 rectifier. I did this mostly because the power transformer I was using simply didn't have a 5 volt winding. I also used a 6BQ5 for an output tube, vs the 6V6. Again, it was because the amp chassis I was using already had a 9-pin socket available and I have a bunch of those tubes. But, it didn't stop there. I also had an 'extra' HiFi SE output transformer here that had both 4 and 8 ohm output taps. So, as this was just an 'experiment'.....why not use all this stuff to see what kind of amp I could make? I'd already made a couple of 'replica' amps, one from the complete MoJoTone kit (including their 'slightly larger than the original' cabinet), and one that I sourced all the parts for individually....that would be a 'best of' amp....and yea, it was well over $600 to build that thing!! Anyway, in the end, I had this nice little 'chassis' amp, built pretty much to the specs of a 5F1 Champ circuit, but with the addition of a choke in the power supply. And.....through some of the speaker cabinets I have around here..... it sounded GREAT!!!
So, I got 'hooked' on these little things, and started building another...then another, and another, and another. After about 6 more of the 'chassis' versions, I decided it was time to find some decent cabinets and see just where these amps I was building actually 'stacked up' against an 'original'. I found an amazing guy who built me 3 'test' cabinets......and they're great examples of what can be done with a project like this!! Beautiful workmanship, and great materials being used. The first was a 10" version of the 'stock' cabinet, made to fit a 'stock' chassis'. The second was another 10" version, but with a slightly larger back panel so as to cover the Hammond chassis I used for my 'altered' design build. The 3rd, and thus far 'last' one is a 12" version, again with my build changes, and on a Hammond chassis that's back to the 5" width.
So, this is my question to the masses here: Have I gone too far? Am I now just WAY beyond the 'original' Champ amp and should no longer even consider representing the thing as a 'Champ Clone', or, it that still just what it is?....a 'clone'?
Attached are a few pics which rather show some of my work here. The first shows 5 of the early 'piggy-back' builds, including the original 'clone' at the forefront on the right side. The second pic shows the inside of my build, also the use of the 6BQ5 and 6CA4 rectifier. The 3rd shows this amp 'mounted' in the 10" finger-jointed pine cabinet, and the 4th shows both my early 'replica' amps, including the high-dollar 'original as well as the MoJoTone Kit, larger box on the right. The last is just a pic of the inside of the amp 'mounted' in the pine box!!
So any opinions here are welcome. My gut says that as long as it's represented as a 'clone' and not a 'replica' or 'duplicate' version, then calling it a 'Champ Clone' isn't a misrepresentation. Honestly, I think it might actually be a bit more of a 'guitar player friendly' amp, as the 10" speaker gives it a bit more punch, the improved power supply makes it both quieter and takes some of the 'flab' out of the bottom end, and I think the 'drive' factor of the 6BQ5 is also a bit 'tighter'....which to me makes me feel as if the amp is just more responsive overall. And.....it's 'louder'!! Hey, what guitar player won't like that, eh?........lol And finally, I think it may be that something like this could be offered on the market for just under the $500 mark.....as you see it in the pics, but 'playable' and ready for it's final owner to 'finish' as they so desire. Anyway, thanks for reading this, and constructive comments are welcome and appreciated. Tom
