5f1 build volume/distortion issue
Discussion in 'Shock Brother's DIY Amps' started by jlang, Apr 1, 2019.
  1. jlang
    jlang TDPRI Member
    Edmond, OK
    Hey all,
    I need some help. I recently replaced a preamp socket and did a few reflows to fix some cold soldering issues. Now when I power it up and plug my guitar in I have about 1/2-3/4 the power I did before the changes. It really only gets to decent volume when I turn it up to 12. I also get a lot more distortion than before, especially when I hit the higher strings.
    Some notes:
    I accidentally turned the amp on, about 1-1.5 minutes, without the speaker plugged in at one point.
    The amp is dead quiet, no weird noises coming out of it. No weird smells, etc. The tubes seem to be fine but I've only kept it on a little at a time to test and take voltage readings.
    I'm also getting a few weird readings:
    My PT is a classic tone 40-18019
    My OT is a classic tone 15 watt 40-18031
    5Y3 Rectifier pins 2 and 8 (yellow): 880 AC
    5Y3 Rectifier pins 4 and 6 (red): 340 AC
    Heater Voltage: 3.1
    Everything below is DC:
    B+1 Measured at the first filter cap: 399
    B+2 Measured at the second filter cap: 335
    B+3 Measured at the third filter cap: 269
    The 6V6's cathode (pin 8): 21 DC
    The 12AY7's plates (pins 1 and 6): (1)132, (6)134
    - Its cathode: 2.0
  2. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Your DC voltages don't look to crazy. If the amp is now playing at lower volume than before, I would check all of the new solder joints that you made when replacing the socket. Chances are you may still have a bad joint that is causing the lower output. Can you post clear pics of the amp's interior?
  3. jlang
    jlang TDPRI Member
    Edmond, OK
    AC2B0A17-065B-4E18-A0FB-4A49E20C8EE4.jpeg 03A13E60-93E9-43C9-BA69-6B7D1A8E40FD.jpeg 335F2E8E-8B53-4567-973A-6B6B041FE530.jpeg A01E011E-D4EB-408B-99B9-DFABE470D47D.jpeg DF1D12CE-5AAC-4391-BA66-912317F3C122.jpeg 1827DB2B-C437-4249-AC7B-58F0BF4B9398.jpeg F8D7146B-6221-4E54-AA66-389F6E41F84F.jpeg It’s ugly. And I pulled a couple of wire that were underneath the board and put them on top. Could it be an overheated volume pot?
  4. intensely calm
    intensely calm Tele-Meister
    Have you made headway correcting this issue?
    If so, what did you find?
  5. Linkjr
    Linkjr Tele-Meister
    Uk
    Did you try changing tubes? Check the ground connections are solid
  6. D'tar
    D'tar Friend of Leo's
    WNY
    Can you confirm v1b cathode resistor... To me it looks black green red. Should be brown green red.
    Both cathodes 2.0vdc?
  7. intensely calm
    Looking at the photos, I don't see any insulator material between the chassis and the turret board. Is there any insulator there?
    The blue SoZo V1A 0.022uf Coupling Cap looks a little toasty, maybe this happened during assembly rather than use.
    My next question needs someone with 5F1 experience to weigh in.
    The 22K Negative Feedback resistor appears to be a 2watt variety in the photo, and the 22K resister between B2 and B3 filters looks like a 1/2watt. Shouldn't the cap at the filters be a 2watt rather than the NFB?
    My guess is these two resistors may be switched, but I would like to hear from 5F1 builders on this.
    King Fan, Paul-T and D'tar like this.
  8. Linkjr
    Linkjr Tele-Meister
    Uk
    Yes my 5f1 schem shows the 2watt between the filter caps not in the neg feedback, I would also def swap out that coupling cap but woul swap the resisters around first (and check the value of the 1/2watt with multimeter)
  9. Paul-T
    Paul-T Tele-Meister
    London
    I agree. I don't know enough about those coupling capacitors to say for sure but they look in poor shape.
    I think if you're working on the board, swapping the 22k resistors around, you should reorientate the 470 Ohm 2W as it looks to be sitting right next to the 22/25 ohm cathode bypass. That resistor gets pretty hot, too.
  10. King Fan
    Salt Lake City
    It looks like the last time we heard from the OP was 4/1...
    Sent from my iPad using Tapatalk
    Paul-T likes this.
  11. allesz
    allesz Tele-Holic
    Italy - Bologna
    Hallo, maybe I'm late, but check the heater wiring: 3,1 Volts are too low.
