5F1 Backpanels
Discussion in 'Shock Brother's DIY Amps' started by OahuClay, Nov 23, 2017.
  1. OahuClay
    OahuClay TDPRI Member
    Longview, WA
    I'm cleaning up a 58 5F1 and am looking for back panels, I checked the mojo tone website and theirs are 12 7/8" wide and this one needs an 11 7/8" wide panel, can anyone shed some light on this?Did the dimensions vary from year to year?
  2. JuneauMike
    Alaska
    Maybe this guy can provide some historically correct guidance.
    http://myfenderchamp.com
    I read your post more closely. Yeah, Weber says Mojo cabs are larger than period correct 5f1s to accommodate modern speaker dims. So I guess no surprise that it's 1 inch wider.
    The back panels on a 5f1 are about the easiest things to build, if it has to come to that. Good luck.
  3. r_o_b_s_o_n
    r_o_b_s_o_n TDPRI Member
    Victoria BC, Canada
    I think mojo is pretty good at working with customer requests. You might be able to get them through mojo... you might have to pay a bit more... but it's likely an option...
