5f1 6v6 bias
Discussion in 'Shock Brother's DIY Amps' started by jlang, Apr 6, 2019.
  1. jlang
    jlang TDPRI Member
    Edmond, OK
    I'm getting the following readings in my latest 5f1 build. I'm I wrong in my math that my bias is currently 14.4? This seems really high for a 6v6 and I can't get a good reading from pin 5.
    Wall Voltage: 123v
    Power Transformer Output: 358v
    Heater Voltage: 6.3
    Rectifier Heater Voltage: 5
    B+1 Measured at the first filter cap: 398
    B+2 Measured at the second filter cap: 336
    B+3 Measured at the third filter cap: 279
    The 6V6:
    Pin 3: 386
    Pin 4: 337
    Pin 5: 0
    Pin 8 DC: 21
    The 12AX7:
    Pin 1 DC: 136
    Pin 3, Cathode DC: 2
    Pin 6 DC: 131
    Pin 8: 2
  2. VintageSG
    Yorkshire
    Have you got the heater supplies mixed up?, it should be signal valve heaters at 6.3 and rectifier at 5, or is it a typo.
  3. jlang
    jlang TDPRI Member
    Edmond, OK
    Sorry about that. That was a typo. I'll edit that now
  4. jlang
    jlang TDPRI Member
    Edmond, OK
    Also, I forgot to add that I have a EH 6V6 and TAD 12AY7 installed. NOS 5y3 Rectifier.
  5. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Pin 5 on the 6v6 should be 0 because the 5f1 is cathode biased and does not need a negative bias voltage on the grid.
  6. jlang
    jlang TDPRI Member
    Edmond, OK
    Ok, thanks @dan40
  7. Snfoilhat
    Snfoilhat Tele-Afflicted
    Oakland, CA
    Plate-to-cathode voltage, Vpk = 386 - 21 = 365 V
    You should have a measurement of you cathode resistor. Let's assume for now it is exactly 470 ohms.
    Voltage drop across the cathode resistor Vk = 21 V.
    Find cathode current, Ik, using Ohm's law. Ik = Vk/470 = 0.045 A or 45 mA
    Plate current, Ip, is estimated from cathode current. In a 6V6GT it is like 90-95% of the cathode current.
    .94 * 0.045A = 0.042 A
    Plate dissipation is plate current multiplied by plate-to-cathode voltage, (Ip)(Vpk) = 15.5 W
    15.5 W / 14 W = 110%
    15.5 W / 12 W = 130%
    https://robrobinette.com/Tube_Bias_Calculator.htm Thanks, Rob!
    peteb, bigguy12321 and monkeybanana like this.
  8. jlang
    jlang TDPRI Member
    Edmond, OK
    Wow that claculater does make things easier. Bad news though, it's worse than I thought. I should probably change out that resistor now. Thanks all for the help. I really appreciate it.
  9. jlang
    jlang TDPRI Member
    Edmond, OK
    @Snfoilhat So, If I use a 500ohm I bring it down to 14.5, which is still over. It looks like the next resistor value is 680ohm, bringing it down to 10.7watts, which seems really cold in a cathode biased amp. Does a value between those two exist?
  10. Uncle Daddy
    Uncle Daddy Tele-Holic
    Maldon, England
    Throw in a JJ 6v6 and forget all about it!
    John How likes this.
  11. peteb
    peteb Friend of Leo's
    Cascadia
    It’s likely biased exactly where it should be. Is there a problem with the amp? I wouldn’t think there would be.
    Are you concerned about the amp or the tube?
    The tube can take it. There are people who expect a single ended 6V6 amp to dissipate at least 16 W in order to sound the best. Older style 6V6s, not even JJs, are known to be able to take 20 W. I’ve seen it myself.
    D'tar likes this.
  12. jlang
    jlang TDPRI Member
    Edmond, OK
    @peteb Well, everything is running ok and it sounds really good playing through it and I haven’t noticed any red plating or anything. I just don’t want to cook the tube or cause other issues because the bias is too hot. The specs for the EH that I have in there shows 14watts max. So that’s really what’s worrying me.
    @Uncle Daddy I have a JJ sitting around so that is an option.
  13. peteb
    Cascadia
    I just lost an EHX in an early end, I just bought a new EHX to replace it because EHX have worked fine in the past and it was only $15.
    check it in the dark. my champs have a little faint (white stripe) running down the center of the plate.
  14. dan40
    Richmond Va
    These little amps have been running hot like that for years and some still have their original power tube. I would button it up and enjoy it right where you have it now.
    jlang and D'tar like this.
  15. jlang
    jlang TDPRI Member
    Edmond, OK
    @dan40 I’ve ordered a few resistors just in case I need them but I think that’s what I’m going to do. Close it up and just have fun with it. At this point it sounds so good I really hate to change anything.
    dan40 likes this.
  16. John How
    John How Tele-Meister
    Auburn, Ca
    You could also use a combination of resistors if you really wanna tweak it to a certain dissipation or just put in a robust tube and use it like has been mentioned...
