5E7 Bandmaster speaker wiring
Discussion in 'Amp Tech Center' started by deepSchmitt, Jul 13, 2020.
  1. deepSchmitt
    deepSchmitt TDPRI Member
    Denver, CO
    Hey guys, I'm currently running the stock wiring setup with 3x10" speakers (8 ohms each) wired in parallel for ~2.6 ohms and using the 4 ohm output from the amp. From what I've read, it's possible to replace one of the speakers with a 16 ohm and then wire the two 8 ohm speakers in series and the 16 ohm in parallel to get 8 ohms so I can use the 8 ohm output. If this can be done, does anyone have a schematic for it?? Much appreciated...
  2. schmee
    There's an 8 ohm output? Is it a clone?
    Anyway, it's fairly easy, but some speakers will have more volume than other speakers like that.
    boredguy6060 likes this.
  3. deepSchmitt
    Denver, CO
    Yup it's a Ceriatone clone with a 4 and 8 ohm output. I know that one speaker will get more power than the other two. Just wanted to try it and see how it sounds. I currently have three AlNiCo speakers and I want to replace one with a ceramic.
  4. schmee
    See edit above.
  5. deepSchmitt
    Denver, CO
    Dude thank you so much! Exactly what I needed.
