Check your power transformer bolts. Transformer laminates can vibrate and caus that kind of hum if they aren’t sung, and can come from the factory that way. My 5e3 builds are dead silent except for carbon comp hiss when cranked up.
The PT is tight to the chassis. I did tighten the screws on the PT itself earlier, so I don't think it's loose. But maybe I can try tightening as much as I can and see what happensCheck your power transformer bolts. Transformer laminates can vibrate and caus that kind of hum if they aren’t sung, and can come from the factory that way. My 5e3 builds are dead silent except for carbon comp hiss when cranked up.
I couldn't feel anything vibrating on the PT housing. Also, if i disconnect the speaker (just super temporarily), I don't hear any hum or vibrations.That must be a clue; I can't remember exactly what it suggests, but our brain trust may know. Filters? PT? What else would hum before the tubes warm up?
No one's mentioned PT hum, IIRC. Can you feel the hum if you touch the PT bell housing?
Filters should be 120, but LLC's easy test of gator-ing in an extra filter cap is pretty easy.
This old article by Paul Ruby has some unconventional or inconvenient steps, but it might be worth a read, like your note about the non-buzzy quality of the hum. Scroll down to the What Causes Hum? section.
http://www.paulrubyamps.com/info.html#FirstPowerUp
I think I'm going insane. I tested with the speaker disconnected and I do hear a slight hum coming from the PT. Once the tubes warm up, it gets amplified a bit more. I don't feel anything vibrating and everything seems tight.You don’t need to crank the PT bolts super hard, but snug is good. If the him goes away with the speaker disconnected, it isn’t mechanical him, it’s electrical. That eliminates another category of hum. Reading through this thread, you’ve eliminated the sources in the preamp, power tubes, and mechanical, correct? At this point, I’d still be leaning towards a grounding issue based on the sound from the video. Is there any change with a guitar plugged in? What about when you touch the strings? As a ‘drop back and punt’ method, you might re flow the solder joints to be sure there isn’t a cold joint in there because those can cause some hard to track issues as well. The 5e3 doesn’t have a lot of joints so it might’ve worth going through the exercise. I also didn’t notice a voltage chart or detailed pics in this thread yet, so those would be helpful as well.
I tried the different ground layout from robrob and it didn't change anything, so I don't think it's anything to do with that. The only thing left I can think of to really try is new heaters and location for them and maybe new tubes to test (matched)Hah. You and Uncle Doug had me convinced it was 60Hz. Maybe a solder joint, tube, or transformer.
120Hz and we are back to the ground loops.
Pictures. Voltages. Please.I tried the different ground layout from robrob and it didn't change anything, so I don't think it's anything to do with that. The only thing left I can think of to really try is new heaters and location for them and maybe new tubes to test (matched)
Tried a different rectifier tube?
@andrewRneumann Yep, tried different 5y3.
