bluesholyman
DISCLAIMER - I properly discharge voltages before digging inside the amp (unless I need it live) and verify with a meter that voltage levels are safe/gone.
I neglected to measure any voltages before I swapped rectifiers as I heard the Sovtek is higher than it should be, so I just put in the JJ and chunked the sovtek - it rattled anyway and didn't want to bother with it.
This VHT has a ~460 Ohm (470 nominal) bias resistor instead of the standard 250 that shows on a regular 5e3 schematic - even the VHT schematic shows it as 250. I suspect for amps running Sovtek rectifiers, they beefed that up to get bias back down? I am looking at all this to change my bias resister to ~250 as is in a stock 5e3
Voltages with 460 resistor and JJ 5y3 with 120v at the wall:
B+ - 366
B+1 - 360
B+2 - 330
B+3 - 253
Bias: 23.5v
Plate current: 23mA
Plate Voltage: 340v
This seems like its presently biased really cold...
So my question is, should I switch that bias resister to something smaller, such as 250? These voltages seem a bit low, but I am not really sure. The amp currently runs fairly clean for a good bit on the volume and it just doesn't have the grind that it did with the sovtek (and chinese tubes). I really have to turn it up to get any sort of non-clean tweedy-ness with a P12Q in it. I'd like it to cook a little sooner if I can.
Would appreciate thoughts/insight. Am I even thinking about this correctly?
B+ - 366
B+1 - 360
B+2 - 330
B+3 - 253
Bias: 23.5v
Plate current: 23mA
Plate Voltage: 340v
