5E3 Power Section Numbers....Voltages Etc
Discussion in 'Amp Tech Center' started by DennisM, Feb 28, 2020.
  1. DennisM
    DennisM Tele-Meister
    Nevada
    Home built 5E3. Was wondering what the ideal B+, Plate voltage, voltage across cathode bypass etc is? What's my goal?
    Here's what I have now:
    Plate=362v
    B+ 1=369v
    B+ 2=336v
    B+ 3=245v
    Across cathode bypass=24.6v
    Cathode resistor=470 ohms
    So, 24.6/470=.052/2=.026A
    .026A x 362v plate = 9.41W dissapation
    Does this look right....are the voltages too high or low? Just checking to see if I'm close to correct tolerances? The amp sounds good with no noise.
    boredguy6060 likes this.
  2. dan40
    dan40 Friend of Leo's
    Richmond Va
    You would normally shoot for a dissipation of 12 watts on the 5e3 but it's not a requirement. The standard 250-270 ohm cathode resistor would likely put you right on target. If you are happy with the amp's sound now, you could leave the 470ohm in and call it a day.
    King Fan and DennisM like this.
  3. dan40
    Richmond Va
    Your voltages look good. If you do decide to try the 250 ohm cathode resistor you may see the b+ drop slightly from the extra current draw which is completely normal.
    DennisM likes this.
  4. DADGAD
    DADGAD Friend of Leo's
    Earth
    With that 470 ohm cathode resistor, you could run a pair of 6K6 pentode outputs. They can be fun.
    Lowerleftcoast and DennisM like this.
  5. DennisM
    Nevada
    I thought the target was 70%? I'm using JJ 6v6's and they handle 14 watts, so I figured 9.4W was a good figure? I started with a 250 ohm resistor and ended up with something like 13W? What would be the result sound wise of a higher dissipation?
  6. dan40
    Richmond Va
    70% has become a guideline many use in fixed biased amps. Most cathode biased amps such as your 5e3 tend to run their tubes right at 100% dissipation. Lowering the cathode resistor should make the amp sound a bit dirtier. If you prefer higher headroom from your 5e3 just leave the 470 ohm in place.
    Lowerleftcoast, King Fan and DennisM like this.
  7. DennisM
    Nevada
    THANKS!! I wondered why it was so clean! :)
    King Fan likes this.
  8. monkeybanana
    monkeybanana Tele-Holic
    mmhmm
    What transformers are you using? I like your numbers :)
    Mr Ridesglide likes this.
  9. cobaltu
    cobaltu Tele-Meister
    New York, NY
    I think you calculation is a bit off. You are supposed to subtract the Cathode voltage drop from the Plate voltage.
    Like this:
    24.6V/470 = .052A/2= .026A
    362-24.6 = 337.4V
    337V * .026A = 8.77W
    I would drop the cathode resistor to ~ 300 ohms.
    dan40 and DennisM like this.
  10. DennisM
    Nevada
    Oh wow. I didn't know that. Stands to reason. I went in an put a 250 ohm in it and it's never sounded this good. Because of my mistaken 70% rule, this thing was was running so cool...didn't sound like what I thought a 5e3 should. Does now! :) I'll measure the numbers in the morning. Thanks to you and all for the help!
    dan40 and King Fan like this.
  11. DennisM
    Nevada
    I got it from Antique Electronic Supply. I heard that they are rebranded Classic Tones, but can't swear to it. It's the one listed on their site for Deluxe, Deluxe Reverb. It's got a 50V bias tap too. I might use this same tranny in a 5f11 build I'm planning.
    monkeybanana likes this.
  12. DennisM
    Nevada
    Thank you too @dan40. You helped me a bunch!
    dan40 likes this.
  13. monkeybanana
    mmhmm
  14. King Fan
    Salt Lake City
    That's a great 5e3 PT. They're not *rebranded*, exactly: AES just sells the wholesale version from Magnetic Components (MC), ClassicTone's parent firm. Other than the even-more-confusing name scheme, they're the same thing from the same company and factory. CT calls this the 40-18016.
    EDIT: I'll be interested to see your new numbers. Are you using Rob's bias calculator? It's super easy since you can use his 'cathode resistor voltage drop' method.
    That 330-0-330 may run your JJs right near 100%. If you don't get to 100%, that's OK, but if you're curious, some folks find standard '12W' 6V6s may sound a bit different -- some say better -- and NOS versions may sound better still. Why do I mention it? The 12W tubes often bias out over 100% -- mine have run between 107 and 112% in my 5e3 with that transformer -- but the sturdy old NOS versions at least can do this all day long. I've run 1953 RCAs and 1947 Ken-Rads for years without issue...
  15. DennisM
    Nevada
    I installed the 250 ohm resistor last night. The new plate voltage dropped all the way to 323v. The cathode bias is now 17.6v. The actual resistance on the 250 is 247ohms. The new current is 35.6mA. All this gives me 10.87W dissipation. I might try Tung Sols or some different 12W 6v6's. Can't afford the NOS stuff. I like the way it sounds much better now, but it's still too much amp for an old bedroom picker. The 5f11 vibrolux is looking better and better by the minute :)
  16. King Fan
    Salt Lake City
    The Tung-Sols are said to sound nice if you get a pair that don't die in the early going. See if you can buy from somebody who gives you a 30-day guarantee -- is 'guarantee' a thing on tubes? :)
    If you're looking for bedroom (OK, music room) levels from a 5e3, you can get great bluesy 'tweed cleans' setting the tone at 6 or below, the active volume at 2-4, and the inactive-channel volume at 9-11. Sit to the left of the amp (away from the PT) and try twiddling the knobs some in those areas. Of course you can plug into channel 2, but that's the same as turning down your guitar... which is a great idea on a 5e3. Turn down the guitar volume so soft pick attack gives notes that sound quiet and clean, but digging in can give you rasp and depth.
    If you want tweed *dirt* at home levels, a good attenuator can help.
    DennisM likes this.
