tele_savales
I have mapped out my p2p project in diylc and drill drilled out an aluminum chassis. I know it's not the ideal chassis to do this in, but I'm going for it anyway, partly because I can't really build a cab to fit a hammond chassis, and partly because everyone builds them with a board and I wanted to do something different that a) required more problem solving and b) I sort of enjoy the additional hassle of laying out and prepping a chassis.
I am using an LED, diode, and resistor network off the 6.3v winding for a pilot light- I am trying to swear off the rassin frassin Fender style lamp assemblies.
I am putting a slotted 2W 100 ohm pot next to the single output jack to run as a humdinger, sending the wiper to the cathode of V3.
I am putting a mini switch between the jacks and the first pot (pre PI MV) to jump the channels without a patch cord.
My only real concern is the coupling caps from V2 crossing near the output transformer on the way to the power tubes. Is this going to be a hum inducing disaster? and should I run them up to a tag strip and then run leads down from there? The capacitor lead from V2 Pin 8 will not be long enought to make it to V4 anyway without being extended.
I did the headphone trick and found the absolute quitest position and orientation on the chassis for the output transformer- right over where the output jack would normally be anyway, 90 degrees turned from the PT.
I'll try to double check the schematic against my birds nest layout and post it this weekend- It's really just a very rough guide, as the few p2p builds I've done were cake pan style and super easy to get to everything. I'm sure there will be some interesting challenges along the way.
