teleman78
Hello Friends, I have a 2-3 year old 5E3 Tweed Deluxe that was build by Anthony Pace from Vintagetone Amps in Alabama. It has Classic Tone transformers and quality components. The amp has been great up until now.. the issue started after I installed some belton tube retainers to avoid tubes getting loose and falling out. I was extremely careful while installing the tube retainers, I made sure not to disconnect any wires or move any components. After putting all back together I started hearing a lot of noise.. but the noise only comes once I play the low E and low A strings and the noise stays present once it comes. I though maybe it's one of the tubes so I started checking that out since I have have a spare set, I replaced one tube at a time and after replacing all tubes the noise problem still remains. What could be causing the noise? The amp seems to be working well other than the noise issue. I’m trying to attach sound samples of the problem but for some reason the website doesn’t accept the files, they are quite small.
Your help is greatly appreciated
