5e3 help
Discussion in 'Amp Tech Center' started by Achysklic, Oct 18, 2020.
  1. schmee
    I see no red wire to pin 8 of rectifier from the OT or to the board either...?
    JamesAM and D'tar like this.
  2. D'tar
    D'tar Friend of Leo's
    WNY
    Yes... you need to re visit your ot connections!!!
  3. Lowerleftcoast
    california
    Good catch. Achy.
    I have used the same OT.
    *If* you have the rest of the circuit wired to the layout.
    Red to B+
    Yellow to V4
    Green to V3
    Blue to output jack tip
    Blk to output jack sleeve
  4. Achysklic
    Achysklic Tele-Afflicted
    Ohio
    I don’t know what to do now I put new rec tube in turn on amp v1 got tube went white and smoke v1 820 ohm resistor. All I know to do is pull it apart and start over.
  5. elpico
    elpico Tele-Afflicted
    Vancouver BC
    You need to use a more sensible start-up procedure than just throwing all the tubes in it and flicking it on. Shouldn't have any tubes in until you've verified the voltage at all the rectifier socket pins is appropriate. Then you put only the rectifier tube in and make measurements at all the other important pins and points. Do you have a lightbulb limiter?
    jman72 and D'tar like this.
  6. Achysklic
    Ohio
    No but I’m going to try to get the stuff needed to build one tomorrow
    D'tar likes this.
  7. D'tar
    WNY
    If you are using the 40-18022 ot your wiring in the photos on page 1 is incorrect. Have you addressed that? Perhaps some new photos.
  8. glenlivet
    glenlivet Tele-Holic
    Marco.......Polo......
    Sounds to me like you have a short somewhere.(I know...big help right?)
    Make sure your rectifier socket is installed/keyed correctly, and that you have the transformer wires on the correct leads. Then double check it.
    After that, start wire tracing, and continuity checking....
    With no power and no tubes.
    Make sure that pin 8 isn't shorted to ground (use the ohm setting on the meter), then start following the path.
    My guess is that somewhere, you have the DC high voltage getting shorted to ground.
  9. jman72
    jman72 Tele-Afflicted
    Central Florida
  10. Lowerleftcoast
    california
    WAG.
    When you fixed the V1 pin8 pin3 issue mentioned in post# 55-56. You accidentally connected pin1 or maybe pin6 to the V1 cathode terminal. Pins 1&6 provide the high voltage to the tube.
    Achysklic likes this.
  11. Achysklic
    Ohio
    I had to order the resistor that smoked this gives me a few days to recheck everything I pulled the board and checking everything on it first. I also ordered new sockets. The ones that I had were horrible and felt so cheap.
    glenlivet likes this.
  12. Achysklic
    Ohio
    I finally got the parts in and put the amp back together. I installed rec. diodes and did mods suggested in post #49. I built a lightbulb limiter. And did a test. It lit up the limited exactly as the one in Robs YouTube video demonstrating it. Only problem is I have no sound out of the amp at all, not even a hum. What could it be?
  13. D'tar
    WNY
    Have you corrected your OT wiring.....
    Voltages and photos again please
    Lowerleftcoast likes this.
  14. Achysklic
    Ohio
    I wired the OT like this. I’ll snap some more pics.
    Red to B+
    Yellow to V4
    Green to V3
  15. D'tar
    WNY
    That should be correct now. Did you move the PI tail resistors noted in post #50?
  16. Achysklic
    Ohio
    272BED9F-E406-4377-ADDD-2B0F459EF370.jpeg A705F477-55BD-4D22-8260-67AD8DFACA83.jpeg BFD87602-9C33-4D0A-94AC-42BFE49F64ED.jpeg 8C7AB1B8-20FF-4DB0-A297-978237813947.jpeg
  17. Achysklic
    Ohio
    BA548493-67C4-4D24-A2A0-57E2C8C38F3D.jpeg 2C65F558-79F2-4B7B-AEFC-620AD4293565.jpeg 06C2572E-BE22-43F3-99C3-720FCED902B9.jpeg 2142305D-A906-4C31-93C3-5CEB59DE76FF.jpeg 2142305D-A906-4C31-93C3-5CEB59DE76FF.jpeg 8F43913C-9A7C-40CA-9E8C-0101C0572368.jpeg A7FF3A7C-D662-41D6-A184-97862D4B4F2B.jpeg
  18. D'tar
    WNY
  19. JohnnyJumpUp
    JohnnyJumpUp TDPRI Member
    California
  20. Achysklic
    Ohio
    Yes that’s what I used. It lit up and did exactly the same as robs did in his video. Just no sound out of the amp when I plugged in a guitar.
