5e3 help
Discussion in 'Amp Tech Center' started by Achysklic, Oct 18, 2020.
  1. Lowerleftcoast
    california
    Meter:
    V with wave form line = AC
    V with line underscored with ... = DC
    Your meter is set for VAC
  2. Lowerleftcoast
    california
    Red probe on rectifier pin8. Blk probe to ground. Meter set to 600 in the yellow section of the dial.
  3. Lowerleftcoast
    california
    If no VDC on pin 8 then switch to VAC and put probes on pin2 and pin 8. We are looking for 5VAC heater voltage for the rectifier tube.
  4. Achysklic
    Achysklic Tele-Afflicted
    Ohio
    No reading
  5. Achysklic
    Ohio
    6.7v on 6v6
    5.5v on rec
  6. Lowerleftcoast
    california
    Check to make sure the rectifier tube is inserted in the socket correctly. You may have a bad rectifier.
  7. Achysklic
    Ohio
    Yes seated really good was a brand new tube
  8. Lowerleftcoast
    california
    .EDIT I had that backwards.
    Rectifier red wires to pins 4 & 6
    Yellow to pins 2 & 8
  9. Achysklic
    Ohio
    I rechecked pins 2,8 on rec VAC they are pin 2 is 2.0v and pin 8 is 2.7v
  10. Lowerleftcoast
    california
    Does the rectifier get warm from heater voltage?
    BTW heater voltage is always measured with a probe on each wire.
  11. Achysklic
    Ohio
    Rec pins 4&6 is 388v
    On yellow pins 2&8 show nothing
  12. Nickfl
    Nickfl Friend of Leo's
    Being brand new doesn't mean it's not defective. You should try another rectifier tube if you have one. You have voltage on your rectifier heater pins but the tube is not heating up which sounds like a defective tube.
    You would also be well advised to be doing all of this plugged into a light bulb limiter until you solve your problem and make sure you have no shorts in your amp. A current limiting device of some sort is a necessary tool for working on amps and going without one puts you at risk of destroying a power transformer.
  13. Lowerleftcoast
    california
    Disconnect pin 8 yellow wire. With power *on* measure with probe on that wire and the other probe on pin2. Looking for 5VAC from the PT.
  14. Achysklic
    Ohio
    Can I make a light bulb limiter or buy one . Also I have no other rec tubes. Plenty of everything else though. Figures
  15. Achysklic
    Ohio
    Ok hang on
    On pin 2 and wire from 8 got 5.5vac
    Lowerleftcoast likes this.
  16. Lowerleftcoast
    california
    If you have 5 VAC on the rectifier yellow wire, then pull the rectifier tube and meter for resistance and/or continuity of pins 2 & 8 of the tube itself.
    Nickfl likes this.
  17. glenlivet
    glenlivet Tele-Holic
    Marco.......Polo......
    https://robrobinette.com/How_The_5E3_Deluxe_Works.htm
    If you look about half way down this page, you should see "Standard 5E3 DC Voltages".
    If you are not getting readings *in the ballpark* of these voltages, start looking at the rectifier wiring and/or the rectifier itself.
    -- but it looks like others have already pointed that out.....
  18. Achysklic
    Ohio
    Umm my rec tube doesn’t have a pin 2 ???? 54CBD090-124D-479D-BD5F-1921F40910A6.jpeg .
  19. Achysklic
    Ohio
    Ok I looked at pins wrong on tube. Anyway it is getting all green lights for good conduct on pins 2 & 8
  20. elpico
    elpico Tele-Afflicted
    Vancouver BC
    It's the pin closest to your thumb in that picture
