5e3 help
Discussion in 'Amp Tech Center' started by Achysklic, Oct 18, 2020.
  1. Achysklic
    Achysklic Tele-Afflicted
    Ohio
    I just finish my 5e3 build. After putting all the components on the board I did a continuity test all was good. I finished it up, turned it on with no tubes, light came on all looked good. Put tubes in, test voltage at light 6.8v then tested voltage on 12ay7 socket same 6.8. Problem is it has no sound no noise at all. Tubes light up and get warm except the 5y3s it does get warm and I can’t see it glow. Help thanks
  2. Achysklic
    Ohio
    F85A6F59-F7CA-4011-AB69-679A76E9D744.jpeg D7F12A11-55DF-497D-9CCB-1A97879BE6CE.jpeg 178639AD-B454-49EB-8DF1-640BB289D1D0.jpeg 5D5DEB18-FA80-435D-8E75-C5119BBC987B.jpeg
    Phrygian77 likes this.
  3. glenlivet
    glenlivet Tele-Holic
    Marco.......Polo......
    Getting the correct B+ across the standby switch? and/or Pin 8 of the 5Y3 ?
    What schematic are you building from?
    What OT are you using? Maybe just the photo angle, but I can't see a B+ going to / from the OT ?
  4. Achysklic
    Ohio
    Classic tone transformers. What should the B+ at standby switch be? And pin 8? I’m using Robs schematic
  5. Achysklic
    Ohio
    I’m gettin 2.4 volts across standby switch pin 8 1.7v
  6. Achysklic
    Ohio
    3211F619-B1F3-4871-B80D-E531B98EF982.jpeg 5104C498-2B11-4F4B-9FB2-31CB5FE091CB.jpeg
  7. Lowerleftcoast
    california
    If you are using the classictone 40-18016 the B+ should be around 370VDC with tubes installed.
    With the amp running, what are the voltages on the positive sides of the filter caps?
    Please provide the voltages on the 6V6 pins.
  8. glenlivet
  9. Achysklic
    Ohio
    I don’t think I’m getting 350v at pin 8 . Do I measure from pin to a ground?
  10. glenlivet
    Yes. chassis ground to pin 8
  11. Achysklic
    Ohio
    Pin 8 I’m getting 1.7v pin 3 and pin 6 I’m getting 380v
  12. Achysklic
    Ohio
    Which pins do I read on the 6v6 tubes I read pin 3 on each tube and it’s 1.5 v
  13. Lowerleftcoast
    california
    Odd reading. Do you have your meter set to DC?
    6V6 example:
    pin3 around 350VDC
    pin4 around 320VDC
    pin8 around 20VDC
    What voltage do you have at the positive side of the filter caps?
    Measure with one probe on the pin and the ground probe on the chassis.
  14. David Barnett
    Do you get any clicks or pops when you measure the voltage at various points in the circuit?
  15. Achysklic
    Ohio
    Nothing
  16. Achysklic
    Ohio
    On 6v6 pin 3,4,8 basically nothing on filter caps nothing. Also 2,7 I get 6.7v
    On 5y3s I get 386v on pins 4 and 6
  17. Achysklic
    Ohio
    The 6v6 are glow and a little warm the 5y3s ice cold no glow
  18. Lowerleftcoast
    california
    You have voltage on the 6.3VAC heaters so the tubes will glow.
    The voltage on the rectifier pins 4 & 6 are VAC. Change your meter to VDC and measure pins 2 & 8 of the rectifier.
  19. Achysklic
    Ohio
  20. Achysklic
    Ohio
    I switched to VDC ON RECIFIERand on pins 2 &8 nothing
