5e3 boot hill amp build
Discussion in 'Shock Brother's DIY Amps' started by Spc10ssss, Dec 14, 2020.
  1. Muzzy
    Muzzy TDPRI Member
    The tone control wiring is right. Maybe the pot is bad. I've seen that with new pots before.
  2. Spc10ssss
    Spc10ssss TDPRI Member
    Bradenton, Florida
    Hey man so I changed the potentiometer and it works now, but I don’t seem to get any crunchy sounds like I’ve heard from other 5e3 it seems to be all clean tones, I really like the clean tones but I thought it would have a little bit of a crunchy sound and I played around with all the knobs and both channels, I couldn’t get anything but clean tones? By crunchy I mean something like la grange, i don’t really know the proper term.
  3. Timmay
    Timmay Tele-Meister
    Nutbush City
    Double check your resistor values. I had a similar situation with lack of gain in my 5f1. Turned out to be a couple wrong value resistors choking out my signal.
  4. Muzzy
    Muzzy TDPRI Member
    Did you use a 1 meg pot?
  5. D'tar
    D'tar Friend of Leo's
    WNY
    ^^This please^^ Each tube every pin. This will let us know if voltage is where it is suppose to be and of the correct value. Also tells if voltage is where it should not be. heaters and the pt HT before the rectifier will be AC . The rest will be DC
    perhaps some fresh photos in good lighting WITHOUT FLASH
  6. Spc10ssss
    Bradenton, Florida
    Yes
  7. Lowerleftcoast
    california
    Boot Hill shows a classictone 40-18002 6k6 - 8 ohm output transformer. What output transformer do you have?
  8. D'tar
    WNY
    Dave often recommends the 6k6 OT.
    What guitar are you using. I find things pretty clean with that OT and single coils. Humbuckers can heat things up however.
  9. Spc10ssss
    Bradenton, Florida
    Ugh so I checked my resistor values and they are all correct, I didn’t check voltage i’m a little nervous about that but I guess it’s my next step, I have no idea what transformer I have whatever he gave me, I play a strat with single coils, I thought that my input jack area was where the problem was so I took out all the jacks and resoldered them, but when I fired it up there was a huge problem it started making a loud noise even with the volume all the way down so I just shut it off and it made a big pop, so the nightmare continues, I’ll try to redo the jacks again today and see if I can measure voltage at the tubes. Maybe it just won’t get crunchy? It definitely sounds different than the you tube videos I’ve heard?
  10. Muzzy
    Muzzy TDPRI Member
    I had the 6k6 ot in my deluxe and it had some grind to it. Not as much as the 8k but, it wasn't totally clean. I've since changed it for the 8k ot which I like better.
  11. Spc10ssss
    Bradenton, Florida
    I checked my voltages:
    With no tubes in
    pilot light- 6.6 v
    Fils 12ay7- 6.6v
    Wy3gt pin 4 - 388v
    Pin 6 - 388v
    Pin 8-2- 5.1v
    with wy3gt, 12ay7, and 12ax7b
    wy3gt pin 8 510v
    Pin 2 510v
    Caps from left to right
    510v, 480v, 352v, the big orange one on the right side was 175v
    with all tubes in and speaker plugged in
    caps 379v, 340v, 251v, Orange- 126v
    12ay7
    Pin 1,6 127v
    Pin 3,8 2v
    12ax7b
    Pin 1-166v
    Pin 6-195v
    Pin 8-45v
    Pin 3-1.2v
    6v6gt both
    Pin 8-20v
    Pin 3-370v
    Pin 4-340v
    Hopefully this helps, it’s still not getting crunchy at all
  12. Spc10ssss
    Bradenton, Florida
    I did have zero voltage where the red circles are?
  13. Spc10ssss
    Bradenton, Florida
    If everything is right does anybody have any ideas for getting a little crunch in the tone?
