5E3 120 cycle hum
Discussion in 'Amp Tech Center' started by tripley, Feb 4, 2021.
  1. tripley
    tripley TDPRI Member
    New Brunswick, Canada
    Hey everyone,
    I recently finished building this 5E3 style amp. The thing sounds awesome but it has a nasty 120 cycle hum going on. I've already gone over the lead dress and the grounding of the amp and I am now at a loss.
    The hum only increases with the volume on the bright channel and the normal volume doesn't seem to affect it at all. When I ground the grid of V1A the hum is tamed and the bright volume no longer has an effect. Any thoughts? See the pictures to get an idea of the wiring (don't worry about the missing input haha, I'm still waiting on some parts so I grounded the normal inputs for now)
  2. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Where's the fourth input jack? Can that have anything to do with it?
  3. tripley
    Yeah don't worry about that, I'm still waiting on some parts so I grounded the leads that go to the input for now (I only have the bright inputs wired up at the moment). That should be fine
  4. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. UK.
    Screenshot 2021-02-05 at 10.34.18.png Why are you not grounding the pot to the preamp ground and using the chassis ... that will cause hum if the chassis point chosen is not a 'star' point.
    loopfinding, Wally and Nickfl like this.
  5. Lowerleftcoast
    california
    Can you show the ground scheme?
    Is there a schematic and layout for this hybrid?
  6. tripley
    PXL_20210201_004758308.jpg PXL_20210205_220454960.jpg PXL_20210205_220501633.MP.jpg
    Here's the whole layout of the amp, I've got the first and second filter cap grounded at the transformer stud with the center tap of the heaters and 380V. The preamp is grounded at the input jack as shown and tied to the rest of the preamp components through a ground plane on the back of the board. I'll post the schematic when I get back to my computer. It's pretty much a 5e3 with an extra gain stage and a reverb circuit.
    Thanks again!
    Lowerleftcoast likes this.
  7. Lowerleftcoast
    california
    Is the speaker output from the OT grounded to the chassis?
  8. tripley
    Yeah it's a mercury magnetic FTDO-59 with the negative lead tied to the transformer housing that grounded to the chassis with the mounting bolt. The outside of the chassis is powder coated so it doesn't conduct but the bolt is fastened inside where it's bare aluminum so there is an electrical connection there.
  9. D'tar
    D'tar Friend of Leo's
    WNY
    5e3?
    Do you have a schematic?
    Is the ground trace separated between the pre and power amp?
  10. 2L man
    2L man Tele-Meister
    Finland
    I have noticed when "ground" and "chassis" are used in a same sentence it cause noise problems :(
    D'tar likes this.
  11. tripley
    Here is the schematic. On the board I have a separate ground plane for the pre amp and power amp.
  12. tripley
    Just a correction on my initial post: its the NORMAL channel that causes the hum to increase with volume.
  13. Lowerleftcoast
    california
    Like Jon said, get the ground off of the pot backs.
    Run a wire from the bright vol pot ground terminal to the normal vol pot ground terminal to the input jack ground terminal where the board ground is connected.
    Run a wire from the reverb pot ground terminal to the ground side of R25. The PI 56k tail resistor.
    Nickfl likes this.
  14. Lowerleftcoast
    california
    duplicate post
  15. schmee
    schmee Doctor of Teleocity
    Nice build! I can't tell ...but the preamp section needs grounded near the input jacks and not grounded near the power end. Is it?
  16. tripley
    Thanks! Yeah the preamp is grounded at the input
  17. tripley
    I've already tried not grounding them on the back of the pot and running a bus to connect them all to the input. No change
  18. archetype
    archetype Fiend of Leo's
    Williamsville NY
    I keep seeing references to 120 Hertz (cycle) hum. Line voltage is 60 Hertz. Am I missing something, or is this an error that keeps being repeated?
  19. tripley
    After rectification voltages will likely have some 120Hz ripple to them so that's where it comes from.
  20. D'tar
    WNY
    Is this a kit? Do you have a layout of the board and the conductive traces?
