"54" tweed deluxe channel crossing
Discussion in 'Amp Central Station' started by fontaine, Mar 24, 2004.
  1. fontaine
    fontaine Tele-Meister
    i have a 3 input 5d3 deluxe. iwas wondering if jumping the two outer inputs and using the centre input would cause spontaneous combustion ? i tried this at very low volume and it does seem to afford a new dimention. any
    thoughts?
  2. Lance
    Lance Friend of Leo's
    Charlottesville, VA
    Doesn't hurt!
    I do it all the time on my Mission 5E3 Deluxe. Noodle around with one knob real high and the other lower....you'll like it.
  3. Silverface
    Lawndale CA
    Hmmmm...I don't even need to jumper the inputs on my '55 5D3 to use the volume controls interactively. In a way, they *are* jumpered internally.
  4. mk
    mk Tele-Meister
    Austin, TX
    It's true that the channels are already interactive, but if you jumper them, you'll get a whole new level of get-up-and-go. Go for it -- it sounds great.
  5. fontaine
    "54" deluxe channel crossing
    it's true the deluxe e.q. is quite interactive. for example the treble response seems to be greatest at appx.
    7 on the dial and the volumes can be twiddled all
    around(twiddled?). i'm just used to my dr that seems so
    hi-tech compared tothis one. i am determined to use this
    amp in my new situation because it sounds so cool and
    is totally different than my other amps. even my ac10.
    which i thought might be similar .i was wrong. just trying
    all the options without anybody getting hurt!
    thanks-j.p.
  6. Skydog
    Skydog Tele-Meister
    I have narrow-panels, wide-panels and BF Deluxes ..each amp reacts differently to settings and jumpering (I don't jumper Deluxes), but do get enhanced tone jumpering the BF Tremolux.
