500K vs 250K Pot in Tone control??
Discussion in 'Shock Brother's DIY Amps' started by bdgregory, Aug 20, 2010.
  1. bdgregory
    bdgregory Tele-Afflicted Silver Supporter
    Virginia
    What is the effect of using a different resistance spec in a Tone stack if all other things are the same? I'm building a "Deluxe like" amp, and the schematic shows tone pots are spec'd at 250K audio taper. I'm considering using 500k instead, for no other reason than I have them on hand and want to finish the amp this weekend. Will I be sorry?
  2. Commodore 64
    Commodore 64 Friend of Leo's
    Kent, OH
    I don't know, but when all I had was 500s on hand, I rewired my Strat. It still works, and I can still make it sound the way I want it.
  3. jrsh
    jrsh TDPRI Member
    MA
    The function of a tone stack is dependent on every component-- generally a combination of resistors, pots and capacitors attenuates specific frequencies by specific amounts. The value of each capacitor in the tone stack is chosen to pass a certain frequency based on the resistance in front of or behind it. So, changing the value of the pots without changing the rest of the circuit will affect how it sounds and will change what happens when you turn the knobs. It's definitely possible to make a similarly designed, similar sounding tone stack using 500k pots, but dropping them in with no other adjustments could work out badly.
  4. limbe
    limbe Tele-Afflicted
    Stockholm,Sweden
    In your place,I would skip the tonestack for now and just connect a 0.022 µF 600v capacitor from the anode of the first preamp tube to the upper lug of the volume control.
    This way,you can hear if everything is working as it should and avoid work that you know you will have to undo.
  5. bdgregory
    Virginia
    thanks guys!
