5 way switching with cocked wah and series PUs
Discussion in 'Tele Home Depot' started by peterg, Sep 25, 2020.
  1. peterg
    peterg TDPRI Member
    Toronto
    I found this wiring diagram on another thread.
    https://www.tdpri.com/threads/string-doctor-c-cked-wah-with-a-standard-5-way-switch.897432/
    It is based on Craig Anderton's 5 way switching except that the bridge pickup has the cocked wah option instead of the neck PU.
    In order to understand the circuits I drew the diagram below. I’m puzzled about position 2. Since the neck pickup white wire is connected to the volume pot and it’s black wire is connected to ground via a cap the pickup will be heard. This position is supposed to have bleed off from the bridge + side only. What am I missing?
    crazydave911 likes this.
  2. dlaroe
    dlaroe Tele-Meister
    Not quite BFE, NC
    It's been a while since I've delved into this and I'm having trouble following either diagram; I'd have to re-draw them to follow them.
    The switching order would drive me batty too.
    It's also often easier to build it then troubleshoot I've found.
    This is what I use. The position 4 that has both the bass cutting and treble dumping caps does have both coils hot.
    Edit:
    You'll notice it's the same wiring with the pickups flipped and a cap instead of a jumper from the hot side to the ground side.
    Deaf Eddy seems to have deleted his tdpri-drawings folder.
