4x2 headstock
Medeltids
California
I wanted to get some input from our collective...is there any “downside” to using a 4x2 headstock?
Seems you just don’t see them much. Personally, I find this configuration visually interesting but have no experience with them.
Cheers.
J
Freeman Keller
Everything I can think of is pretty minor. You'll need two sets of tuners and have a 2x4 set left over unless you are able to source s 4x2 set. If you play other guitars you might find yourself fumbling for the tuner button. It looks like that guitar got by without a tree for the middle strings, lay out your paths carefully. Otherwise it should be fine
schmee
I see no down side. If one was using logic then maybe 3+3 makes the most sense.
Medeltids
California
Thanks Freeman. 4x2 sets are available...even 2x4. Not ubiquitous but available.
ctmullins
MS Gulf Coast
No downside, just upsides: more compact headstock, possibly less need for those annoying string trees.
Jim_in_PA
SE PA - Doylestown PA
It what I've adopted for all of my builds other than the very first one. I buy the tuners in 4x2 matched sets (Gotoh) so there's no leftovers. My bass is 3x1 in the same respect and I bought the tuners individually to suit.
JohnnyThul
Germany
You can use Sperzel tuners and rebuild them individually for left or right use.
It's one of the reasons I really like them and as far as I know the only machine head, where that is possible.
dogmeat
Alaska
all things equal... it will be slightly more top heavy because the weight of the 4 tuner is farther out than the position it would have on a 3x3. but.... probably less top heavy than 6 in line
Medeltids
California
Thanks for the input. Aesthetics aside, mechanically it appears sound and no string tree is definitely a +.
As for bending the B string above the nut, not really an issue for me. I’m not that clever.
GunsOfBrixton
Rochester, NY
I used it on my last original Design builds. no issues at all.
88 asat
East Texas
What I was gonna say, and swaping from left to right is easy.
bullfrogblues
Southeast Florida
I've used the 4x2 on the last 5 guitars I made. I bought locking Hipshot 4x2 sets from Sporthitech.com. I love the looks and I'm now used to reaching for the high E string on the bottom!
New Posts
