42 & 43 gauge wire in a Tele
Discussion in 'Just Pickups' started by AJBaker, Dec 24, 2013.
  1. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    A traditional Tele uses both, with 42 gauge on the bridge and thinner 43 on the neck. But some prefer broadcaster style bridge pickups with 43 gauge wire, and some like strat style neck pickups with 42 gauge wire.
    You can have:
    1) traditional (43 neck, 42 bridge)
    2) both with 43 (broadcaster)
    3) 42 neck and 43 bridge (baja telecaster)
    4) both 42
    Of the 4 possible combinations, which do you prefer, and why?
  2. fakeplastic
    fakeplastic Tele-Meister
    NV
    I've never really understood the tonal differences between 42 and 43. I'm aware that 43 is a smaller diameter therefore it allows for more turns around the bobbin, but why someone would pick one over the other is still a mystery to me.
  3. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    What does the Rob say? (Rob D., Cavalier Lion master pickup winder):
    "for me, there's just some more "girth" and "fatness" and "sweetness" in a tele/esquire pup that uses 42awg instead of 43awg coil wire."
  4. copperheadroad
    copperheadroad Tele-Holic
    Botwood,Newfoundland,Canada
    2 tele bridge pickups with the same dimensions same number of turns & winding pattern recommended tension & only wire size being the difference 43 gauge will have more midrange ,Less bass & overdriven will break up a little easier/quicker than 42 gauge wire .
  5. 4pickupguy
    4pickupguy Poster Extraordinaire
    Fort Worth, Texas
    Ill be watching this thread a lot as winding my pups is the next phase in my builds. On an off topic note, AJ Baker, are you in Bern Switzerland? I recognize that mtn in your avatar.
  6. D.Allen
    D.Allen Tele-Holic Vendor Member
    SF Bay Area
    If everything is the same except the wire size the 43 will have lower output, inductance, capacitance and resistance all lower if number of turns are the same between the two bridges. Now if you wind them to approximately the same output (not resistance) then you will hear the tonal differences.
  7. Derek Kiernan
    Derek Kiernan Friend of Leo's
    Princeton, NJ
    Resistance goes up with the same length as wire gets smalller in diameter. In a well-wound coil, so does density, which increases voltage output. If you get shorts because you can't deal with finer wire, however, output can be destroyed.
  8. AJBaker
    Switzerland
    That mountain is the Matterhorn, and I grew up in front of it in the town of Zermatt. My avatar is a picture from a gig up in the mountains. These days I'm usually in the Rhone valley near lake Geneva though.
  9. AJBaker
    Switzerland
    Looking at Rob's page, it's really helpful that he lists turn count and dcr.
    Looks like the Nashville lion (8k) and the Nocaster lion (10k) have about the same turn count, just different wire gauge. Has anyone tried both? I'd love to.
