4 way with coil tap
Discussion in 'Tele-Technical' started by metalicaster, Feb 15, 2018.
  1. metalicaster
    metalicaster Tele-Afflicted
    I'm a wanderer...
    OK, I've got a stacked pickup - I like the full on tone as a "boost" position, but it doesn't play well with the neck - and doesn't allow a twangy bridge pickup tone.
    It does these things well when split.
    I'm probably just being blind, but how would one wire a 4 switch to give.
    Neck
    Neck+Bridge(one coil)
    Bridge (one coil)
    Bridge (Both coils series)
    First 3 positions I can work out - almost regular tele wiring. but the forth position is eluding me.
  2. Wally
    put a push/pull on the pickup to go from bucket to single coil or from series humbucking to parallel humbucking.
    The leads from the switch go to the 4-way.
  3. metalicaster
    I'm a wanderer...
    I guess If I do it with a push/pull I could do it with a regular old 3 way - I don't want neck/bridge series in any combination anyway.
  4. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    The above suggestion is in addition to the 4-way you need a toggle or a push/pull to do what you want.
    Four way will get you series/neck/parallel/bridge between the pickups then if you want the bridge to be either single coil or humbucking you use a toggle or push/pull.
    You might bend a 5-way super-switch to your exact switching order, but they get pretty complicated to set up.
    I'd suggest a 3-way on/on/on toggle switch to change the bridge on its own from parallel/single/series and then the 4-way to do series/neck/parallel/bridge operations between the two pickups.
    Or you use a 5-way switch to run all three coils like a Strat and you have a concentric tone/blender pot to go from SSS to HSH.
    Of course, the easiest is a 3-way Tele switch with a push/pull to split the humbucker.
  5. moosie
    Western Connecticut
    Here ya go:
    RomanS likes this.
  6. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    The switch
    I searched the web and can t find a schematic for a 4 way .. Is it 2 pole 4 position w NO shorting of adjacent positions? If so you can do your switching...
    The 2 poles are +A and +B.
    4 Neck.....+A hot from Neck
    3 Neck and 1 coil of Bridge....+A Neck hot, +B Bridge coil junction
    3 Bridge one coil...+B Bridge coil junction
    4 Bridge... +A Bridge hot
    It depends how the Stack is wired you may have to reverse the wiring if the bottom coil is grounded.
  7. moosie
    Western Connecticut
    You've more or less described what I drew in the post above you.
  8. Teleterr
    Lewes De.
    Sure enough. Problem solved. Bridge South would be the top coil.
  9. Wally
    I like more versatility than that when I have 4 wires on a pickup ..or two....and a four way switch. ommv.
  10. moosie
    Western Connecticut
    And of course north and south could be swapped in the diagram, if desired.
    For a full size HB, I usually try to split the outside coil, to get the most separation.
  11. Silverface
    Lawndale CA
    FWIW it's also thinner/brighter - assuming it's in the bridge position and the outer coil is closest to the bridge. If it's in the neck position the game changes....
  12. moosie
    Western Connecticut
    Ah, wording... when I said "outside" coil, I meant the coil closest to the bridge, in the case of a bridge pickup. Or the one closest to the headstock in the case of a neck pickup. I try to avoid getting that positional wording conflated with north/south, start/finish terminology.
    So, yeah, I figure if you want to split the bridge, you want that bright sound. Why do you say the game changes with neck? Because one might wish for the bridge-most (aka inside) coil, to achieve a more balanced, less muddy sound? If so, I could get on with that. I figure at that point it's personal taste.
    I have no dog in the fight, I just make wiring diagrams for people who want them. I used to wire my guitars all manner of ways, but since I never used any of it, I no longer bother.
  13. Silverface
    Lawndale CA
    The "outside" coil is the "screw coil" and is normally closest to the bridge - on the bridge pickup.
    Because the neck "screw coil" is normally closest to the neck (yeah, I know that sounds weirdly redundant - but some might no know) and will be "less bright" than the slug coil.
  14. metalicaster
    I'm a wanderer...
    Perfect, just what I needed, sometimes I get dumb moments where I'm outsmarted by switch logic.
  15. moosie
    Western Connecticut
    That's my point. We're talking about the same thing.
  16. moosie
    Western Connecticut
    Oh, I know the feeling.
    After staring at Fender switches for so long, I have a healthy respect for the efficient, clever design. I've never seen these exact switches (3, 4, 5 way) anywhere else, I wonder if Leo had a hand in inventing it?
