4 Way Switch wiring question
AV64LPBlue
Missouri
I would like to install a 4 way switch in my Telecaster, however I would like the neck pickup only position to be all the way forward and the bridge only to be all the way back, and then the two different pickups combined settings (series/parallel) to be on the two middle positions on the switch. I played a Tele that had the 4 way switch installed from the factory and the neck only choice was on the number 2 setting on the switch which I did not like. Is it possible to wire a 4 way how I want it and if so does anyone have a diagram?
Thanks!
sjtalon
Upper Peninsula of Michigan
Second from the top, on the left
Your neck pickup needs to have three wires (if it has a cover......dedicated ground). If you don't know what that means, let us know.
