Canyon Creek
Very long time lurker, first time poster so apologies about my etiquette in advance.
I'm trying to build my ultimate Tele (at least for a week until I think of another mod).
Basically, I want to have a 4 way rotary switch on the upper bout for pickup selection (Bridge, Bridge & Neck Parallel, Neck, Bridge & Neck Series) a la Telecaster Custom but still have a traditional Tele switch plate consisting of 1 x mini-toggle and 3 x pots (blend/tone/volume). Mini-toggle (or a 4 way rotary switch) for position 1. off (ie signal passing through without any of these options affecting the output), position 2. HOOP, position 3. straight to jack/bypass tone & volume and position 4. HOOP & straight to jack (if I can't have position 4 it's not a deal breaker - just thought it would be good to have the option).
Then I'd like a blend pot like the one found below but not concentric - just a pot for the blend. Next is the tone wired like the one in the link below and last pot is for volume.
Essentially I want this wiring with the HOOP added on the mini-toggle (https://www.premierguitar.com/mod-garage-the-super-flexible-super-simple-telecaster-wiring) combined with this way of blending (https://www.radioshoppickups.com/product/telecaster-prewired-harness/). Is it possible?
I'm still deciding on the neck pickup but am probably going for a Gemini Suprocaster in the bridge. I'm leaning toward a Ricky High Gain in the neck (wanted a CC but may be too dark in series. Also wanted a Dynasonic but they are a bit too deep for my Tele body). I play rhythm in a alt-country band and mainly use the middle position into a Fender Deluxe Reverb and use flat wound 12's if that helps.
Any advice would be greatly appreciated. I have no idea re restrictions when it comes to wiring. Also any recommendations of who could wire up a harness for me too would be greatly appreciated. Thanks in advance.
