4-way Switch Question
Discussion in 'Tele-Technical' started by Praxis, Dec 14, 2019.
  1. Praxis
    Praxis Tele-Meister
    Out There
    Is it possible to wire a 4-way switch to give the following combinations?
    Position 1: bridge pickup, with tone control
    Position 2: bridge and neck pickups, in parallel, with tone control
    Position 3: neck pickup, with tone control
    Position 4: neck pickup, tone control disengaged
    I don't have a 4-way switch in front of me to try and work out how to wire it up, so I thought I'd toss this question out here and see if anyone has done this.
    I find I use the neck pickup with the tone control wide open 99% of the time, and I use the bridge pickup with some degree of roll-off 99% of the time. So it's kind of fiddly to have to be adjusting the tone control every time I switch pickups. I'm thinking the 4-way might be a handy way to go for me, if it'll work.
    Thanks
  2. 63 vibroverb
    63 vibroverb Tele-Holic
    Lititz, PA
    I don’t think it’s possible, but I’m open to being corrected if anyone figures out a wiring to do that.
    You could always use a “no-load” tone pot, to take it out of the circuit when you go to the neck pickup.
    Personally, the whole point of getting a 4-way is to get the pickups in series for a setting.
    Zepfan likes this.
  3. Deaf Eddie
    Deaf Eddie Friend of Leo's
    Beautiful Idyllwild, CA
    I'm also gonna say no... I think you need another pole to make the tone pot come and go.
    paperoil likes this.
  4. Praxis
    Praxis Tele-Meister
    Out There
    Thanks, everyone.
    Another solution I've kicked around is installing a push-pull tone pot, wired to move the tone control from its standard place in the circuit, to the bridge pickup's 3-way switch lug.
    Geo likes this.
  5. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    That or since you use the neck pickup tone up full 99% of time just remove it from the tone control.
  6. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Use a no-load tone pot and on ten it's out of the circuit in any position.
