30's Philco Radio as parts for DIY amp build
Discussion in 'Shock Brother's DIY Amps' started by frederickk, Oct 9, 2019.
  1. frederickk
    frederickk TDPRI Member
    West side
    Hi all,
    I recently came into possession of an old Philco radio (Model 39-25 from ~1939). It definitely has seen much better days and I have no interested in restoring it. I was hoping I could harvest parts (transformer, tube sockets, chassis) for a DIY 5F1 Champ build.
    Below are some gut shots, as you can see it's a little rough. The covering on the transformer wires was breaking off (I tried to get a close-up), but would it still be a viable amp transformer anyway? Are the Philco parts of good quality? Or should I just stick to the plan of sourcing parts new?
    Thanks in advance!
    Ken
  2. 1300 E Valencia
    Fullerton CA
    Now, that is point-to-point.
  3. mndean
    mndean Tele-Meister
    Northern California
    Don't think you'll find much usable here. What you can harvest is pretty limited. You get only one octal socket and a PT which you'll have to solder new wires to if it works, and you'll have to test what voltages it puts out, though it might be okay considering the power tube it drives. It could be worth something to a person who restores Philcos for some usable parts, but not very good for a Champ build.
  4. gusfinley
    gusfinley Tele-Afflicted
    SLC, UT
    What is the tube compliment?
    If it has oddball tubes like a 50R4 it may not have a Power Transformer. In this case, you'll want to get a power transformer and almost only the output transformer may be useful.
    If it does have a power transformer, it is intended to be used with 115VAC and if you give it a more modern 123-ishVAC then you will get rather high plate and filament voltages. I recently thought I might salvage a similar transformer, but the heater winding was putting out almost 9 volts!
  5. gusfinley
    SLC, UT
  6. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    Check out the many YouTube guys who transform things into amps. They often start with radios, cabinets and chassis both, but often use just the cabinet and/or just the chassis. Lots of incompatibility and grounding issues 'tween radio guts and amp innards. Be careful!
    These gents do talented and interesting conversions:
    D-Lab
    https://www.youtube.com/user/dlab500
    Buzz1151
    https://www.youtube.com/user/Buzz1151
    The Guitologist (if you can stand/ignore his politicking)
    https://www.youtube.com/user/electrictoothsyndrom/videos
  7. Wyatt
    Wyatt Tele-Afflicted
    At best, you have a chassis, tube sockets, PT, OT, and knobs. Resistors and caps will be useless, they just aren’t stable from when that was built. NOS pre-war resistors are only sold for jewelry anymore.
  8. frederickk
    West side
    You've confirmed my suspicions, I'll look to salvage the chassis and maybe the sockets. I'l pull out the transformers to assess their condition more closely, but with the notion that I'll need to source new transformers for my Champ build.
    I'll also poke around on some of the Philco forums to see if there's interest in what's left, unless someone on here is interested in the bits I don't use, PM me.
    Thank you all.
