3 wires on the CS Nocaster nk pU?
Discussion in 'Just Pickups' started by LUVLEO, Jun 14, 2011.
  1. LUVLEO
    LUVLEO TDPRI Member
    new york
    I bought a set on another forum and the neck came with 3 plastic coated wires (blk wht yellow)I thought there were only 2 cloth (blk wht) wires? How can I be sure? If its correct where does yellow wire go?
  2. Durtdog
    Durtdog Poster Extraordinaire
    Tennessee
    The only one I've seen with 3 wires like that is the Dimarzio Twang King.
  3. SPUDCASTER
    Grangeville, Idaho
    One wire is a cover ground. If you add a 4 way switch it's already to go. I'm not familiar with your pickup, but it's usually the yellow wire for the ground.
  4. moonshiner
    moonshiner Friend of Leo's
    Milyucky, Whiskonsin
    Usually..
    Black = coil ground
    Yellow = cover ground
    White = hot
    But.. I have never seen 3 wires on a Nocaster pickup nor have I seen them with plastic coating.
  5. newmachine
    newmachine Tele-Meister
    Indonesia
    as far as I know, Fender pickups with three wires are : Twisted Tele, Texas Special, SCN and N3 pickups.
  6. sjtalon
    sjtalon Doctor of Teleocity
    Upper Peninsula of Michigan
    Somethin' fishy there unless the previous owner replace the wires. Should have a white and black cloth.
  7. Guitarmadcat
    Guitarmadcat Banned
    Colchester, England, UK
    Seems like you got a 'Twisted Tele' pup there. That's the colour code they use, with plastic-coated wires.
    Is it taller than a regular Tele neck pup? If so - 'Twisted' it is.
  8. LUVLEO
    LUVLEO TDPRI Member
    new york
    not sure as I don't have another to compare it to. Any idea how tall they are or how tall a standard nk pu is? I may try it out and see if I like. Got any idea what the spes are and what these sound like? I hope the brdg is a Nocaster at least
  9. sjtalon
    could be this ?
  10. Guitarmadcat
    Guitarmadcat Banned
    Hi there, the approx. height of a Twisted (I have two) is 19mm. as opposed to the average height of a standard Tele neck pup - 15mm. these measurements include the fibre baseplate.
    Hope this helps, 'Cat.
  11. LUVLEO
    LUVLEO TDPRI Member
    new york
    Thats it!!
  12. moonshiner
    That's more than likely not a twisted tele.. Looks like a custom wind... OEM TT necks have black/yellow/green plastic wires.
  13. sjtalon
    The one I pictured ( blk yellow white) is the one from the Custom Shop.
  14. newmachine
    Indonesia
    Yep, that is a pic of CS Twisted Tele
