3 way switch - series in middle position?
Discussion in 'Tele-Technical' started by tube.tone, Jul 6, 2009.
  1. tube.tone
    tube.tone Tele-Meister
    Northeast
    Is this possible?
    Thanks:?:
  2. SatelliteOrders
    SatelliteOrders Friend of Leo's
    Lafayette, IN
    Yes.
    I don't have a circuit for you, but I've seen one.
  3. cc9cii
    cc9cii Friend of Leo's
    Sydney
    I may have time tonight to draw one up.
  4. Wally
    Simply treat the neck pickup the way you would for the 4-way switch thing. That is, cut the cover connection to the 'ground lead. Run a new wire from the cover to ground. Switch the two leads ....black to switch and the 'lead' white to ground. Voila! series!
  5. cc9cii
    Sydney
    Just like Wally said. Should look like this. The blue line represents shield, which you must separate from ground on the neck pup for this to work. The green lines are optional, most don't bother.
    I've not drawn the jack wires nor the bridge ground.
  6. Wally
    CC, why not just take the cover to ground and switch the contact points of the two leads from the neck pickup? What was the hot lead now would go to ground with the cover lead, and what once was the ground lead would go to the point on the 3-way switch where the erstwhile 'hot' lead was.
    Why the complexity? We are just switching the two leads after separating the cover ground. This will yield the series link in the middle.
    I am sitting here with a 3-way switch in my hand andlloking at your diagram. I see no way that this circuit works. Again, explain it to me and I will be willing to learn....but I can't see it right now.
    There is no reason to rewire the 3-way switch.....except to take the black lead from the neck pickup to the point where the yellow or white lead once made contact.
  7. Deaf Eddie
    Deaf Eddie Friend of Leo's
    Beautiful Idyllwild, CA
    That's not series, that a phase reverse.
    It works, but you have to get your head around this: we are controlling the neck pup, whose hot lead is always connected to the volume pot, by switching its negative (aka"ground") lead.
    In the bridge only throw, the neck's negative lead goes nowhere, so the neck pup doesn't sound.
    In the neck only throw, the neck's negative lead is connected to ground, so it plays.
    In the series throw, the neck's negative is connected to the bridge's hot lead, so it plays in series.
    This is EXACTLY the way the Fender 4-way switch works, here we have just eliminated the parallel combo.
    Here's a drawing I did a few years ago when this question came up. It does the same thing, but perhaps the different drawing style will make it easier for you to see how it works:
  8. Wally
    Okay, CC, I see what's going on....finally. I didn't have quite enough caffeine this morning, I suppose. My apologies.
  9. cc9cii
    Sydney
    No probs Wally :p As usual, Deaf Eddie has the patience to explain it carefully, while I draw something and then run away :D
  10. Wally
    Thanks, Eddie.
  11. woodman
    woodman Grand Wazoo @ The Woodshed Ad Free Member
    Mint Hill, NC
    just my opinion, but while i realize how valuable the series can be, why not go 4-way and have series plus parallel?
  12. tdowns
    tdowns Former Member
    That's what I was thinking. :)
  13. thetantric
    thetantric TDPRI Member
    florida
    How could I do this with a jay turser tele with this type of switchhttp://stashbox.org/438291/3wayswitch.jpg
  14. SPUDCASTER
    SPUDCASTER Poster Extraordinaire
    Grangeville, Idaho
    Welcome to the forum. I couldn't bring up your site for the switch.
    We call this a "zombie" thread since it's so old. It's okay, you probably didn't know.
    The moderators will probably lock it.
    Deaf Eddie also has a wiring diagram for a push/pull and a 3 way for the series position. You keep the standard 3 way and from whatever position your in it will go to series when the p/p is engaged.
  15. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    It's a Patent Pending switch.
    The wiring is like the import switch
  16. Peter Rabbit
    Peter Rabbit Tele-Holic
    Toronto, Ontario, Canada
    Tux: I don't think that can be the same switch, in thetantric's pic, there are hard-wired connections between lugs 2&3, 4&5, and 6&7. In your pic, only 4&5 are connected.
    thetantric: a pic of the writing on the switch might be useful, and maybe a description of how it was wired, and its functions, when it was originally installed.
  17. Deaf Eddie
    Here's the switch image in question:
    We'd really have to know the lug assignment to say yes or no, but looking at the lugs that are hard wired, I'm leaning NO. Get a new switch.
  18. waparker4
    Philadelphia, PA
    Could still use the same internal wiring.
    thetantric: To use the 3 way for a series with THIS switch, you will have to cut those hard wired connections between the terminals. Then I would suggest taking a multimeter to the switch to map out what terminals are connected to what and confirm it is like Tux's pic, and get back to us in a new non-zombie thread. :cool:
    I would +1 eddie's suggestion to just buy a new switch -- preferably the CRL or oak grigsby switch.
  19. Tuxedo Poly
    Merseyside UK
  20. thetantric
    florida
    Tux's pic looks pretty close, this is my diagram, its my first one, the black lines are black cables, the red lines are white cables, yellow is clumps of solder, one finger on the volume knob is bent back and soldered to its back. The blue is a capacitor on the tone knob[​IMG][/URL][/IMG]
