3 way switch question/diagram help please
Discussion in 'Tele Home Depot' started by Chordophonic, Jul 17, 2014.
  1. Chordophonic
    Chordophonic Tele-Meister
    Isle of Wight UK
    So I'm putting together a Partscater, but being cheap Im using parts I already have. The guitar will be 3 pickup ala Strat, I have a spare Tele 3 position switch, can it be wired to give, Bridge, Middle and Middle and Neck? with 2 tones ala Strat. If it is possible a diagram or link to one would be fab!
    Thank you!
    Paul
  2. soulman969
    Englewood, CO
  3. Chordophonic
    Isle of Wight UK
    Still wading through the above but cant find what I am looking for.....fab link though!
    Paul
  4. Chordophonic
    Isle of Wight UK
    The sounds I use the most are bridge only or in between neck and middle, so am looking for a way to achieve this, other positions are of no use to me! I have been reminded that the original Strat had a 3 way but that would mean trying to wedge the switch in the in-between position…………..Is there a solution with a 3 way?
  5. Arch Stanton
    Arch Stanton Tele-Meister
    Dartmouth, NS, CA
    How bout a 4 position toggle switch
  6. waparker4
    Philadelphia, PA
    I drew the tone pots in the wrong order, but just feed the tone pot you want from the pickup lead you want.
  7. dazzaman
    dazzaman Tele-Afflicted
    Gent, Belgium and Lancaster, England.
    Someone else can probably say why it won't work, but if you have the three pickups going to positions 1 (neck), 2 (middle) and 3 (bridge) on side one of your selector switch (and the output from position 4), perhaps a wire from position 2 (middle pickup connection) to position 3 (as in, the position the selector engages with on the other side when you have it in bridge position) on side two of the switch would do it (along with a wire from position 1 (side two) to position 4 (side one) for the output from that side. I hope that makes sense - I can't draw it on this computer.
    It might, on the other hand, just give you bridge and middle in both positions 2 and 3.
    A drawing would really make that easy to show, sorry...
  8. Chordophonic
    Isle of Wight UK
    Thanks folks!
    Paul
  9. Chordophonic
    Isle of Wight UK
    So, Ive followed the diagram above and it works! with a small reservation, It selects the pickups as I want, Bridge, middle, middle and neck, the tone nearest the volume appears to work on the middle pickup, but the second tone doesn't appear to do anything, this is scientifically tested by tapping each pickup!
    How could I modify the wiring so the first tone works on the neck and the second tone works on the middle?
    waparker4 thanks for the diagram!
    Cheers!
    Paul
