2x12 cab finally compete
Discussion in 'Shock Brother's DIY Amps' started by itsGiusto, Sep 28, 2021.
  1. itsGiusto
    itsGiusto Tele-Holic
    Massachusetts
    Hey, just wanted to update those of you who have been following and helping me. Here's my final product for my Dumble-y 2x12 cab of that I tolexed, grill clothed, and added hardware to, to pair with my ODS clone I built:
    The theme of this build is "everything is way the f*** harder to do than you think it's gonna be". I just faced so much trouble in ways I didn't expect, like even tasks that should be simple like putting the handles on top. It was challenging to figure out how to measure them out perfectly, then the screw holes got too close to the cleat inside and I had to route out extra space in the cleat with my drill to make room for the tee nut, etc. For the grill cloth, it was a major pain to try to get it even tension all the way around. For the metal corners, it was really challenging to get them to conform to the wood and I needed to get creative with my rubber mallet, and in addition, I had to figure out how to countersink the corners, something I wasn't expecting to have to do. Basically every task I did for this cab, I faced some unforeseen problem.
    Though it's a 2x12, I'm really running it as a 1x12, one of my speakers in there is not hooked up. I wanted a larger cab so it didn't sound boxy, and I happened to have this raw 2x12 already around. The hooked up speaker is a WGS take on the EVM12L. I have yet to play through it, though, since it's very late. I'll do so tomorrow.
    Thanks everyone for your sage advice along the way!
  2. GreatDaneRock
    GreatDaneRock Tele-Afflicted
    Central FL
    Gorgeous build, the hurdles faced only make it sweeter to have it finished.
    How does it sound though???
    northernguitar, PhredE and itsGiusto like this.
  3. Jackadder
    Jackadder Tele-Holic
    Western Australia
    Yes, clatter a couple of hurdles, take some bark off, but the satisfaction at the finish line can't be beat. Looks beaut!
    itsGiusto likes this.
  4. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Goonieville, OR
    I think it looks good, and anyone would feel good about being seen onstage with it.
    Your post reminds me of coming off the road one time & removing all the Tolex, sanding the glue off, & stripping the hardware from a half dozen monitor wedges because they didn't fare well after 6 weeks of summer festivals and fairs, then taking them to the bed liner place to be sprayed. Not a task to get excited to do over, for sure.
    Timbresmith1 and itsGiusto like this.
  5. Leonardocoate
    Leonardocoate Tele-Holic
    Ohio
    Wow! that's a nice job!....will you be wiring the speakers in series or parallel? I put a toggle switch on mine that can bounce for 16 to 4 ohms..that will give you more amp options..just curious
    Mouth and PhredE like this.
  6. Dana Rudd
    Dana Rudd Tele-Afflicted
    Greybull, WY
    Looks great, nicely done job, enjoy it.
  7. Vocalion
    Vocalion Tele-Meister
    It looks like those handles will make it easier to move than recessed handles. Looks good, too.
  8. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Looks great.
    Just don't buy those style corners again. It's a mistake we can all make once. :)
  9. FenderLover
    Minnesota
    That's a cool rig. I've always liked the idea of the Dumbleator in the same cabinet, but wonder why I've never seen the same cabinet with one more RU to add a Lexicon processor.
    sds1 likes this.
  10. Tele Slacker
    Tele Slacker Tele-Meister
    South Carolina
    Well done! Very nice!
  11. itsGiusto
    Massachusetts
    I'm thinking I may build a Weber Revibe to go in the Dumblator FX loop.
    FenderLover and sds1 like this.
  12. DrBGood
    DrBGood Tele-Holic
    Sutton QC, CANADA
    Nahhh they're fine, you just have to know that the corners have to be snipped off for ½" at 45° before you Tolex the whole thing. Then they fit like a glove.
  13. Timbresmith1
    Timbresmith1 Tele-Afflicted
    Central TX
    Those corners can be beat into compliance with a rubber mallet. Easy and fun !
  14. Mouth
    Mouth Tele-Afflicted
    U.S.
    I went a step further and wired mine up like this, but mine is home brewed.
    So when the switch is set to stereo, each jack is an 8 ohm load(I circled the 8 ohm marking because it's hard to notice) and when set to mono, 1 jack is the 4 ohm wiring and the other is the 16 ohm wiring(choose only one at a time).
    Jewellworks and Leonardocoate like this.
