2x10 speakers for deluxe reverb?
Discussion in 'Amp Central Station' started by teleile, Aug 2, 2021.
  1. teleile
    teleile TDPRI Member
    Finland
    Hi all,
    I have a 65 ri deluxe reverb with a 2x10 baffle loaded with two wgs veteran 10s. I really like the vet 10s vintage tone but was considering other options too, so any recommendations?
    Also would you say 1x12 is better than 2x10 configuration?
    Thanks.
    Tele295 likes this.
  2. Novak
    Novak Tele-Meister
    Los Angeles
    I think one 12" speaker might be better than a single 12" speaker in an amp, but not as good as than 2 10" speakers. And don't give me that "10 inch speakers don't have enough bottom" argument; the legendary Ampeg SVT bass amps had 8 10" speakers. My Orange 32 has 2 10" speakers and IMO ounds amazing.
    Pcs264 and teleile like this.
  3. Hpilotman
    Hpilotman Tele-Holic
    Oklahoma
    1 x 12 is different than 2 x 10 not necessarily better. The speaker cones project sound differently. I like the Eminence Legend 1058 speakers in a 2 x 10 setup.
    I have owned both 1 x 12 and 2 x 10 amps and like both speaker configurations.
    Its your amp and you can run any configuration that you like.
    The Fender Vibrolux Reverb 2 x 10 is still popular with some players.
    https://reverb.com/item/40909630-fender-vibrolux-reverb-1966-blackface
    https://reverb.com/item/42622350-fe...2-channel-35-watt-2x10-guitar-combo-1970-1980
    The Peavey Delta Blues Amp was offered in a 2 x 10 or 1 x 15 configuration.
    My favorite is 4 x 10's in a Super Reverb or 59 Bassman.
    My second choice is a 1 x 12 and third is 2 x 10's.
    Some folks like 1 x 15 and I would like to own a 64 Fender Vibroverb with 1 x 15.
    nojazzhere and teleile like this.
  4. Ricky D.
    Ricky D. Doctor of Teleocity
    Marion, VA
    Love the one you’re with!
    I never mod unless I have a specific goal and a reason to believe the changes will get me there.
    nojazzhere, JL_LI, Hpilotman and 4 others like this.
  5. Blue Bill
    Yep, what Hpilot said: it's a little different, but not necessarily better. It depends on 2 things: What you like, and what kind of speakers are involved.
    Hpilotman likes this.
  6. theprofessor
    Chattanooga, TN
  7. zeppelinofled69
    zeppelinofled69 Tele-Meister
    Western NY
    I have a 68 bassman that has been put in a 2x10 combo cabinet, and it's one of my favorite amps to take out for jams. I had a set of Jensen MOD 10" 40 watters in there, but recently swapped those out with a Weber 10F100 that I have had for years and a Jensen Jet Falcon 10" which tamed some of the highs a bit.
    I personally really like 10" speakers, so if given a choice of 1x12 vs 2x10 I will take the 2x10 every time...
    teleile, johnnylaw and Paul G. like this.
  8. corliss1
    corliss1 Poster Extraordinaire Platinum Supporter
    Lansing, MI
    The vet 10s are a little darker. If you wanted a more classic Fender sound from 10s, I'd try the G10C.
  9. Bob Arbogast
    Bob Arbogast Tele-Afflicted Silver Supporter
    Lowell, Michigan USA
    I put a 2x10 Deluxe Reverb together a few years ago. I have loaded the following speakers into it:
    • Greenback 10 + GA10-SC64
    • Greenback 10 + Fender V1030
    • GA10-SC64 x 2
    • V1030 x 2
    • GA10-SC64 + V1030
    That last combination is where I stopped. The amp is plenty loud, and the tone is all Fender. Generally, I have preferred mixed speakers in this amp. With a mixed pair, each speaker compensates for the peaks in the other speaker's response.
    NOTE: I stuck with very lightweight speakers for this amp.
    In my Vibrolux Reverb, I tried many, many speakers before settling on a pair of V1030s. (There are several threads here about that journey.)
    theprofessor and nojazzhere like this.
  10. Tele295
    Tele295 Poster Extraordinaire
    Ventura CA
    “Good” is a matter of taste, so everybody’s different. That said a 2x10 DRRI would get you a good way into Vibrolux Reverb territory, and that ain’t a bad thing!
    teleile, Bob Arbogast and timbgtr like this.
  11. schmee
    I've done 2 x 10 in BFDR. Been years now.
    I had two Weber 10F150's, 50 watt, 16 ohm that I liked best.
    - The amp was a bit loud though for clubs with those speakers.
    -The amp was now a lot heavier.
    -It sounded lucious though with those speakers.
    I tried other speakers, Greenbacks, Jensen RI C10Q's some others.
    A C10Q with a 10F150 was pretty nice... kinda like the C10Q acted as a tweeter/crisp tone to go with the robust 10F150.
    In the end , nothing is better than a 12" Ga SC64 Emi in the DR.
    But if you could get two GA SC 64 10" in 16 ohms it might be cool...
    I once had a nice 4 x 10 cab made for that DR. Man it was great, BUT... it's the same as carrying a Super Reverb around. Same size, a couple pounds less weight.
    2 x 10 is not near the same as 4 x 10.. even if it has the same speakers.
  12. black_doug
    black_doug Friend of Leo's Silver Supporter
    North of Toronto, Ontario, Canada
    I plug my Dr. Z Z-28 into a 2x10. The Dr. Z speakers are made by Eminence I think. It’s about the the same power as a DR, with 2 6V6s.
    I’ve thought about getting a 1x12 but it sounds great as is.
  13. Hpilotman
    Oklahoma
    One of the best Tube amps I ever played thru was an early Mark Samson Bad Cat 18 R combo with 2 x 10's.
    [Arlington TX Guitar Show late 1990's - early 2000's]
    black_doug likes this.
  14. johnnylaw
    johnnylaw Tele-Afflicted
    New England
    2X10 is my preferred configuration in a combo amp.
    I enjoy the seek and tweak with gear to an extent, but were I in your shoes, I’d just flog it as is until I was certain that making a change would satisfy my curiosity or add to my satisfaction.
    Have fun!
  15. theprofessor
    Chattanooga, TN
    I do not have nearly the experience with 10 inch speakers as Bob Arbogast, but in my Vibrolux Reverb, at least, I have really enjoyed mixing a ceramic and an AlNiCo. For that amp, I settled on a 1978 CTS ceramic + an Eminence 1028k.
  16. randym
    randym Tele-Meister
    Pewaukee, WI
    While my Vibrolux Reverb is now gone, I do have my SuperSonic 22 head through a Tremolux 2x10 cabinet. On the Normal channel that's almost a DR. And I've run with an additional 2x10 cab to be a faux Super (and run the same 2 cabinets off my 68 Custom Princeton Reverb).
  17. randym
    randym Tele-Meister
    Pewaukee, WI
    More 2x10 goodness: my CPR with an external 10 on the other side of the room, and my Vox AC10 through a 2x10 16 ohm cabinet. Can you tell I like 10's (especially 2x10's)?
  18. Dukex
    Dukex Tele-Afflicted
    SoCal
    I'd consider pairing one Vet with a 10" AlNiCo of similar efficiency (Weber 10A100, Weber Sig 10 A).
  19. 39martind18
    39martind18 Friend of Leo's
    Spring TX
    I've posted about my 1970 DR on several occasions, but here we go again! When I obtained this DR, I had a couple of JBL D110Fs available, so to me, it was a no brainer to construct a 2x10 baffle and put them in. I took the mods a step further and installed a solid state rectifier and 6L6s. This mod gives the bottom major focus and more clean headroom. Since I play clean 95% of the time, the 6L6 mod works well for me.
    The JBLs give the sound a definite punch, and I love the way the sound "spreads." It seems wider and somehow fuller than a 1x12 (maybe it's the fact the tens are moving more air than a single 12. Plus, there's the visual aspect: those dual chrome domes look cool as all get out peeking through the grill cloth! 20190103_223839.jpg 20190104_001049_001.jpg
    incontrol54 likes this.
  20. 39martind18
    Spring TX
    I've also used those JBLs in a Blues Deluxe Reissue with great sonic and visual results. D110s are quite rare and pricey, but the K110 versions are a bit cheaper and more plentiful, with the sounds basically identical. 20180518_164225.jpg
