2n3904 vs bc109?
MrCoolGuy
Fort Worth, TX
If a fuzz pedal uses 2n3904 transistors... (a 2-transistor fuzz...) could you use bc109's instead? If not, why? They are both NPN... what am I missing?
loopfinding
europe endless
You can practically use any Si transistors you like for any fuzz, it’s just the biasing points and gain are going to be a little different. So you either have to tweak your resistor/coupling cap values, or maybe in some cases you want more or less of saturation/cutoff weird stuff.
MrCoolGuy
Fort Worth, TX
Yeah, i kinda understand that... and im willing to change values as necessary...
But I swapped in some bc109's in this circuit (instead of 2n3904's which worked fine) just to hear the difference... but i get nothing.
kbold
BC109 pinouts are C-B-E
2N3904 pinouts are E-B-C
In other words you may have put it in backwards ... remove, turn around and resolder.
Wound_Up
Shreveport, LA
I replaced the 2n2222a's in my fuzz with BC109C's with no issue. Just make sure you have the pinout correct as long as they're both NPN.
kbold
Tab is pin#1=Emitter. pin#2 is Base, pin#3 = collector common to case.
https://my.centralsemi.com/datasheets/BC107.PDF
What you say is correct, so I should perhaps rephrase or explain.
I am in effect referring to the plastic TO-92 packages. I use those as my point of reference: flat face forward, pins facing down.
2N3904 = E B C TO-92A package (labelled as pins 1 2 3)
BC549 = C B E TO-92F package (labelled as pins 1 2 3) BC549 is the plastic cased (non mil-spec) equivalent of the BC109.
Some TO-92 transistors have a rear offset to the middle leg, making their footprint the same as metal can packages (direct drop in replacement).
So you can rephrase the BC109 as:
BC109 = C B E Emitter at Tab TO-18 package (Labelled as pins 3 2 1)
(From Wikipedia)
TO-18
(C-B-E)
Emitter is closest to tab
I omitted the use of numbers to avoid adding confusion (which it seems to have done for you).
I stand behind my earlier post.
cherryburst1
(From Wikipedia)
TO-18
(C-B-E)
Well, sorry but I'm not the one confused. The OP said he had BC109's, not BC549's. BC109's are not BC549's.
The BC109 is still available and it's original case, the TO-18. You are cross referencing different components with different pinouts. The BC549 was introduced later than the BC109 and has half of the current capabilities than the BC109, hence the TO-92 package..
THe OP stated he was using BC109's so we must assume he knows which transistor he has.
Therefore, the datasheet stands as reference. Tab (pin 1 Emitter, pin2 Base, pin3 [case] Collector.)
So unless the OP stated the wrong transistor number, I stand by my earlier recommendations...
MrCoolGuy
Fort Worth, TX
They are NewJersey Semi. BC109's. TO-18. And from what youre all saying, I put them in correctly. I'm not sure whats going on. The pedal worked fine with the 2N3904's...
cherryburst1
Transistor checker? You might have a dead or leaky one...Cold solder joints should also be checked.
If no scope and generator, look at the voltages on the devices to see if E>B, E>C and B>C are correct. Low voltages, no voltage drop across collector resistors or wrong bias voltages E>B will help tell the tale....
