2k or not 2k
Discussion in 'Finely Finished' started by dr jeckil, Jan 24, 2020.
  1. dr jeckil
    dr jeckil TDPRI Member
    Massachusetts
    Wondering what people’s opinions are on 2k clears for my latest build. Or just stick with nitro the quick cure of the 2k is very appealing. Came this far and want to finish off the way this top deserves......
  2. Stardog75
    Stardog75 Tele-Meister
    Seattle
    Wow thats beautiful
    Jlwctn likes this.
  3. jfgesquire
    jfgesquire Tele-Holic
    Lake View
    I'm about to try a couple 2k finishes myself, one color, one clear, but will require quite the respirator system.
    I'm also looking at a 3rd option, Solarez, UV cured polyester resin.
    Sent from my LG-H932 using Tapatalk
  4. arlum
    arlum Tele-Meister Gold Supporter
    O'Fallon, MO
    I don't know what 2K is but that top looks wonderful !
    Skydog1010 likes this.
  5. wadeeinkauf
    wadeeinkauf Tele-Holic
    Monterey CA
    I have done some testing with Solarez Polyester Gloss Resin. In the end I do not use it. It cannot be thinned. You will need to do a lot of sanding and then polishing. I found that it was NOT crystal clear. It is a great finish, hard and durable but it does not have the clarity of nitro or any 2K top coat. On the other hand I use the Solarez grain filler product on all my builds when I need a grain filler. I put a Simtec 2K top coat (Fenders Top Coat) on over the Solarez.
    Wade
    Skydog1010 and jfgesquire like this.
  6. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    Is there a preferred 2K tutorial anyone would suggest?
  7. dr jeckil
    Massachusetts
    Thanks for the heads up right now I am leaning towards trying the 2k gloss partly because of the short cure time but it’s also cold up here in the hell hole known as Massachusetts. I have been planning on trying it one of these days just didn’t want to experiment with this body but nothing ventured nothing gained at least that’s what they say....
  8. jfgesquire
    Lake View
    Thanks for your input.
    I have used their sanding polyester as a base coat filler and agree it was thick, but it was designed to sand easily and it did come out nice under an acrylic lacquer (dupli-color).
    I was hoping that warming up the gloss would help it flow a little better before curing it. I'll probably try it once just to teach myself a lesson, but I've been warned!
  9. 1bad914
    1bad914 Tele-Holic
    Michigan
    What do you want to know? Mix it per the data sheet provided online or from the shop you bought it from. It has the the mix ratios and the wait time between coats. After that you wait 24 hours and start wet sanding and polishing. Let me dig up a document I wrote about painting a car. It includes info on clear coats and wet sanding and polishing.
    RodeoTex likes this.
  10. dr jeckil
    Massachusetts
    I will try and get the 2k shot onto it in the next couple days depending on temps no heat in the garage is a *****. Then I will post some pics and impressions when done just sanding sealer on her as of now. For all it’s pluses nitro leaves a lot to be desired so if a 2 part clear works out well it would be nice to be done “for the most part” with nitro....
  11. 1bad914
    1bad914 Tele-Holic
    Michigan
    Not sure I can attach a pdf, but if you want to read the car painting doc that goes through 2k CC let me know and I can email it.
  12. wadeeinkauf
    Monterey CA
    Just love your color on this. What dyes did you use and what finish do you have on the body now?
    I went searching a few years ago trying to find out what the major manufactures are using for their top coats. I found the name Simtec and called them. They say they sell a lot to Fender and and if I remember correctly Taylor. At any rate that is all I use now and it is great. Easy to spray and takes Colortone dyes and really takes House of Kolor Kolor Koncentrates really great. I do use a good respirator mask that I purchased at my local auto paint store...I also use good quality rubber gloves. I use a $40 Harbor Freight spray gun and have also use their $15 one (on sale) with good results. You can thin the Semtec urethane with a good quality urethane reducer. Below is a link to my test of Simtec. I use the 57x1 Top Coat. It is not listed on their website. Call them and tell them what you are doing and they may have a suggestion on another product. You can pay with paypal...the website does not say this but they do take it.
    https://www.tdpri.com/threads/my-test-of-simtec-2k-urethane-fender’s-top-coat.704659/
    Wade
  13. RodeoTex
    Nueces Strip
    I guess my real question is whether I can get my lacquer busrt right then spray on a good hard clear coat.
    I'm sure they don't want to discuss compatibility issues, thus my question.
  14. wadeeinkauf
    Monterey CA
    It is a very good question and many of us who are not paint experts just want to know what can go with what. You will almost never get a clear answer from the so called experts. They will tell to to try it a see it things are compatible. In general I have been told that you might/probably will have issues when you but something hard on top of something soft. Nitro is soft...2k is hard. I have also read guys doing just that with nitro and having it work fine...The question is what happens in 1 or 2 years...I don't know. I learned on nitro...left it because in my experience it is just not a durable finish. So I went looking for a 2K product that I could use just like nitro for my bursts. Simtec lets me do this much like nitro. I can use the same ColorTone dyes and the pretty much the same techniques. You may be able to use any automotive 2K clear coat and get the same results...I know Simtec works and they are here in California so I receive it in 2 days.
    Wade
  15. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Remember not to skimp on the face mask when using 2K. That will harden in your lungs just as easy as it does on a guitar.
    I'd avoid nitro.
  16. dr jeckil
    Massachusetts
    I used transtint orange and amber mixed with water I think water flows better than alcohol. The only finish on top of the dye so far is sanding sealer. Thanks for the nice words as I think we all know to get a decent looking dye and finish is a lot harder than it looks but it is a joy doing it. On to the 2k.......
    wadeeinkauf likes this.
  17. dr jeckil
    Massachusetts
    I will check out Simtec and c if it is available in my area. Thanks for the suggestions.
  18. dr jeckil
    Massachusetts
    Forgot the back which is also a maple cap was done in transtint medium brown and the mahogany center came to life with just a dab of color and matched well with the back..
  19. dr jeckil
    Massachusetts
    A shout out to aqua coat gel grain filler as I used that for the first time on this body and I was very pleased with its application and results. I have a flame maple neck for this project that I did but I don’t really like the color of the finish should have went with a darker dye under the clear and I may go back and strip, dye darker and clear it in a satin finish coat . I will c how the 2k comes out and get it all up here before assembly..
    old wrench likes this.
  20. Deathray
    Deathray Tele-Afflicted Silver Supporter
    Central illinois
    Breathtaking beauty, there! Nice job.
