Hi, I’m about midway through a 50w 2204 build, I haven’t installed the board yet. I’ve just put in the PT (APD Heyboer) - it’s only wired up to the HT fuse, all heater wiring is complete to tubes sockets in 18G wire.
I’ve used the 240v tap on the primary of PT (it also has a 220v tap), mains voltage of 236v.
With tubes out, I get 6.33v at heater terminals, however with all tubes installed (there’s nothing else connected to tube sockets yet) this drops to 6.10v. I’m also only getting 297VDC from the HT fuse to ground, shouldn’t I be expecting 420-450v? The PT secondary is measuring 646vac, I get 590VDC between the rectifier +ve and -ve (which isn’t used).
Does this sound right? Thanks.
