21 quid for deoxit
Discussion in 'Tele Home Depot' started by Diytelecaster, Mar 6, 2021.
  1. Diytelecaster
    Diytelecaster Tele-Meister
    I've got crackly pots and switch on my tele and read on here about deoxit. It's £21 here in England. What is the best alternative.
  2. Musekatcher
    Musekatcher Friend of Leo's
    meridianam altum centralis
    CRC I've been told. I just ordered some to try. I've used WD40 in the past, as a last resort.
  3. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Worth every penny (pence). Never use WD40.
  4. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    Is it the hazmat shipping upping it? Possibly find someone brick and mortar selling it.
  5. brookdalebill
    Austin, Tx
    Indeed, do not use WD40 for this purpose!
    It is a silicone-based lubricant, not a cleaner.
    A little DeOxit goes a long way.
    Great stuff, a can will last a long while is you use it properly.
  6. ricknbaker
    ricknbaker Tele-Afflicted
    Watford, UK
    This
  7. northernguitar
    North of Toronto
    But make sure whatever you use on pots or sliders has a lubricant, ie. Deoxit.
    brookdalebill likes this.
  8. VintageSG
    Yorkshire
  9. Musekatcher
    Last resort guys. Do you know what last resort means? And I was talking past tense. As in, from experience. Did I mention as a last resort?
    brookdalebill and northernguitar like this.
  10. Sparky2
    Sparky2 Friend of Leo's
    Harvest, Alabama
    CRC is available at most hardware and electrical supply stores in the UK.
    Less than 9 quid.
    Also available there:
    WD-40 Specialist Electrical Contact Cleaner
    (This is NOT the WD-40 water-displacing lubricant.)
    £7.19 at ToolStation there.
    Action Can EC-90 Contact Cleaner
    500ml
    £6.99, most stores.
  11. northernguitar
    North of Toronto
    Agreed on a Deoxit can lasting a long time. My can is 13 years old and 3/4 full. Unless one is cleaning soundboards, an average guitar player with a decent collection of gear should get a lifetime out of one can.
  12. mtjo62
    mtjo62 Tele-Holic
    StatesVegas, NC
    MG Chemicals, ACL Staticide and as mentioned CRC are all good alternatives to Deoxit and are usually lower priced. I have even found CRC products in automotive parts stores. Do not use WD40 as a electronic cleaner unless you want a mess. However, WD40 does make contact cleaners which I use for work.
  13. Musekatcher
    CRC is available at Home Depot btw. Found some online, but decided to order it anyway, with some guitar parts. Laziness rules..
  14. Phrygian77
    Crawfordville, FL
    This is the second thread I've seen recently about the high cost of DeoxIT. The bottom line is that it has a pretty good reputation. I use it myself, and a number of techs that I respect also use it.
  15. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Pro Tip: buying Caig Deoxit makes you spend more than you need to.
    Instead, buy the Hosa Deoxit. It's made by Caig for the Hosa company, and it's usually about $5 cheaper. Crazy, but true.
    Compare prices and you'll see there's a difference, but it's the same product.
  16. northernguitar
    North of Toronto
    NO CONTACT CLEANER ON POTS!!!!
    Y’all hear that?
  17. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    Deoxit "Gold"? :)
    Actually it's pretty good stuff.
    A little bit goes a long way.
    It even has the variable spray tip for a short, medium, or long blast.
    I use it as needed, and the can I bought about six years ago or so (at Radio Shack) still feels pretty full.
    It'll fix a scratchy pot like nothing else.
    northernguitar likes this.
  18. old wrench
    WD 40 is a little over-rated.
    Thank Dog the stuff evaporates :).
  19. Diytelecaster
    Ta for the replies. Can I safely assume that deoxit does not damage or melt paintwork.
  20. northernguitar
    North of Toronto
    I haven’t noticed any problem. I’d only be concerned with a nitro finish. Even then, it doesn’t spray, it shoots in spurts. One shot, right in the pot and all will be good, no mess. Remember to work it in by turning the pot with the cleaner inside.
