2019 #6 amp build - 6AQ5 P/P
Discussion in 'Shock Brother's DIY Amps' started by RollingBender, Sep 28, 2019.
  1. RollingBender
    RollingBender Tele-Afflicted Vendor Member
    SW Minnesota
    Time to build another amp. I’ve gone round and round on what to build and after a few false starts, I finally settled on this odd mixture.... a Carmen Ghia front end and a 6AQ5 power section, long tail pair phase inverter and cathode biased.
    Chassis starts as a section of 2” x 4”, 1/8” wall rectangular aluminum tubing.
    End caps are made from solid aluminum and are machined to fit into the ends of the tubing.
    The ends are installed and then the tubing is machined top, bottom, front, and rear.
    03F44557-B897-4B9B-A7F4-F459E73A3B4A.jpeg E9B83554-100B-4A97-AEF3-83EE5018DDB0.jpeg
    Then I fill in the engraving with black paint, let it dry, then sand the whole thing with a random orbital sander and 220 grit paper. Clean it all off and give it a coat of satin clear.
    While the chassis cures, drill the board and install the turrets.
    ....and then solder on a bunch of passive electronic components.
    It’s a tight fit!
    This build is actually a bit of experiment in packing 10 pounds of stuff into a 7 pound bag. If it works out, I hope to do another build with a similar circuit packed into half of the total space.
    Wally and jsnwhite619 like this.
  2. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    Nice! Love the chassis work!
    Sent from my moto g(6) using Tapatalk
  3. RollingBender
    SW Minnesota
    Definitely a very tight fit!!!
    D702A26A-1DBA-403F-9FE1-908A3D46D4C3.jpeg 4FE79247-95A6-4337-A657-6279686327A0.jpeg 543E0141-8D60-471A-9505-C91D7875B0D9.jpeg
  4. RollingBender
    SW Minnesota
    Got it all stuffed in and wired up only to discover that my PT is smoked. New PT on order, scheduled to arrive on Thursday. I opted to jump it up a notch and ordered a Hammond 269BX which has secondary voltage more appropriate to the 6AQ5 tubes and it has the same footprint as the 269AX that is on there right now.
  5. magic smoke
    magic smoke Tele-Meister
    Quantum Entanglement
    What smoked the power transformer?
  6. RollingBender
    SW Minnesota
    ...my lack of understanding of solid state rectification probably. I may have done something when I was bench testing diode and filter cap combinations.
    Lesson learned...thankfully it isn’t too expensive of transformer.
    magic smoke likes this.
  7. magic smoke
    Beautiful work, thanks for the process shots!
  8. Diverted
    Diverted Tele-Holic
    Bristol RI
    Bummer on the transformer. But a really cool build!
  9. RollingBender
    SW Minnesota
    While I wait for the big brown truck to arrive, I decided I might as well keep things moving forward by filling my shop with sawdust and wood shavings. Ended up with this...
  10. BigDaddy23
    BigDaddy23 Tele-Holic
    Great stuff! I love the chassis you build.
    What is the circuit based on? SS rectified by the looks
  11. avspecialist
    avspecialist Tele-Meister
    Avon,Ct
    I HAVE TO SAY THIS IS THE NICEST FULLY SCRATCH BUILT PROJECT INHAVE EVER SEEN, I WISH I WAS THAT GOOD.
  12. corliss1
    corliss1 Poster Extraordinaire Platinum Supporter
    Lansing, MI
    You should leave more room between the cathode resistor and bypass cap. Much like old champs, that resistor will cook the cap over time.
  13. RollingBender
    SW Minnesota
    New transformer arrived a day early!!!
    All wired up, start up procedure complete....an amp is born. Doesn’t sound like anything I have built or played but it sounds really nice so far. I need to check the bias and such. The tone control is very unique. It’s almost like sweeping a wah pedal and it works opposite of normal (that’s how the Carmen Ghias operate). I may go in and rewire the pot “backwards” just because of that oddity.
  14. RollingBender
    SW Minnesota
    I’ve been “field dressing” leather couches and chairs for a couple years...the ones which are thrown out on the curb during city wide clean up days each spring. The great thing about couch hides is they are already tanned and dyed.
    I took one of the smaller strips and covered the head cabinet. This is the first attempt at using leather to cover a cab and I must say that it is wonderful to work with. I have some details to attend to yet...a bit more glue in a couple corners and dab a bit of matching color shoe polish here and there and it should look pretty good.
    I did some experiments with adhesives a while back and found ordinary Titebond to be the best choice. It holds pretty quickly but gives enough time to move things around so it all fits nice.
    Best of all, if it starts looking ratty I can take it to the guy at the airport for a fresh shine!!!
    I will make the front panel from plywood and cover it with a cream color leather from a different couch.
    King Fan, Prophetsnake and Snfoilhat like this.
  15. RollingBender
    SW Minnesota
    Every head deserves its own cabinet. This will be a sealed back single 10” speaker.
    I have 4 choices of recycled organ grill cloth to use. Which one do you like best? (Far left is the burgundy colored leather which will cover the cab. Far right is the cream colored leather that will be the head’s faceplate).
  16. monkeybanana
    monkeybanana Tele-Holic
    mmhmm
    Wow, what a pro. Never seen Olson capacitors before. Will have to Google.
    Hope you record it for us!
  17. RollingBender
    SW Minnesota
    Front panel on the head cut, covered and installed and progress on the speaker cabinet.
    I went through my stash of 10” speakers and this one sounded the best. From it’s reported history, it is theoretically a 16 ohm speaker. I think it’s a CTS and those should be 8 ohm. It meters at 23 ohms. Shouldn’t an 8 ohm speaker read 6 or 7 and a 16 ohm speaker read 12-14 ohms on the meter?
    jimytheassassin and Edvin like this.
  18. jonrpick
    jonrpick Friend of Leo's
    Marietta, GA
    It's probably a 32-ohm speaker... They used 4 of those in the Bassman 10.
    David Barnett likes this.
  19. RollingBender
    SW Minnesota
    This is why I love this forum....you learn stuff! Probably should dig a little deeper in the speaker stash.
    jonrpick and Junior Little like this.
  20. RollingBender
    SW Minnesota
    Got the cab covered and grill cloth installed.
    Just need to figure out what I want to do for the speaker jack, cover the back panel of the cab and figure out some sort of handles that will match the rest of the build. (and either find a way to get that little stain off the grill cloth or tear it off and install a new piece)
    I also ordered an Eminence RF10C to go in the cab. Currently I have a gold Celestion which sound OK but I would like to squeeze as much SPL out of this as I can.
    Edvin likes this.
