2004 DRRI needs a new rectifier 5V4GA or wait for a 5AR4 ???
Discussion in 'Glowing Bottle Tube Amp Forum' started by blues bondsman, Apr 27, 2020.
  1. dan40
    dan40 Friend of Leo's
    Richmond Va
    Sounds like that power tube went bad. If you swap the 6v6's position, does the redplating follow the tube or the socket? If it follows the tube you know the tube is bad. If the redplating stays on that particular socket then you may be loosing bias voltage on that socket.
  2. blues bondsman
    blues bondsman Tele-Afflicted
    Indiana
    I'll try another known pair of good 6v6 tomorrow.
    but first I'll check voltages on the pins.
    Goofy thing sounded amazing for about ten minutes LOL
  3. blues bondsman
    Indiana
    Well...
    My plate voltage is 454 volts !
    My strongest rca 6v6 are at 24ma with the bias pot all the way down.
    This is with the new 5v4ga rectifier
  4. blues bondsman
    Indiana
    I'm replacing all of the filter caps including the 100UF 100 Volt Bias supply cap.
    dropping R59 to 10K from 22K to expand the range and a few other touch ups to bring this 16 year old girl back to usefulness.
    The transformers all seem to be within spec so...
    I have a pair of JJ 6V6S just in case the plate voltage stays at 454 volts.
    The bright cap was clipped and now will sport a 10PF silver mica cap.
    I've done this before and it works wonders on the reverb channel
