2-pickup H/S wiring question
Discussion in 'Just Pickups' started by gregulator450, Sep 21, 2020.
  1. gregulator450
    gregulator450 Tele-Afflicted
    The Dry Side
    Hey gurus,
    I am rehabbing an inexpensive s-style partscaster that was my main guitar for a few years. It has a bridge humbucker and a single coil in the neck with a 3-way switch.
    I recently found a wiring diagram that will coil split the bridge pickup in the middle position for (hopefully) a more tele-like sound. Diagram below...
    My question is this- if I went to a 4-way switch with this coil split wired in, would it put the split coil into series with the neck single coil, or would it put the full humbucker into series with the neck single coil? Thanks in advance!
  2. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    It says single/single, but it would be parallel, right?
  3. gregulator450
    The Dry Side
    In the middle position, yes. I am wondering how a 4th position for series would work. Wondering if it would take one coil from the humbucker and put it in series with the neck single coil?
  4. hopdybob
    hopdybob Tele-Afflicted
    netherlands
  5. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    Or this
    garrett and jfgesquire like this.
