#2:Neck-through Reverse Body Bird
Discussion in 'Tele Home Depot' started by Slowtwitch, Aug 19, 2019.
  1. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    With the success of my very first build, a complete build, https://www.tdpri.com/threads/novice-first-build-the-jawbone.909907/, I was keen to do it again.
    This time something different, way different:
    A through-neck, reverse headstock, Firebird Tele kinda thing.
    So there are T-Birds out there, most have bolt-on Tele necks. I wanted a tele neck but not bolt-on.
    So geometry becomes something I had to sort out first (no neck angle, or high protruding fretboard)
    Some answers came...https://www.tdpri.com/threads/firebird-geometry-questions.954947/
    I got some reclaimed wood (an ex-kitchen counter made of the same Kiaat wood my #1 was made of)
    This one was going to be painted a colour.
    I also received a very nice piece a Beechwood - the centre piece/ neck
    Treadplatedual and Fiesta Red like this.
  2. Slowtwitch
    South Africa
    IMG_20190610_103903.jpeg IMG_20190610_115845.jpeg IMG_20190610_150851.jpeg IMG_20190709_153438.jpeg
    Made templates, had a buddy with a table saw and planner & thickness planner sort out the rough wood
    Routed trussrod, and I decided to glue-on the wings early in the build. That's just how I decided to do it. Some attach the wings later in the build, but I wanted to "protect the joined edges. I didn't find it too much of an issue working with the full guitar as opposed to just the neck piece
    Tele neck template used - neck/ body interface is somewhere between fret no. 16/17. I still use the theoretical heel position to determine bridge, pups, etc
  3. Slowtwitch
    South Africa
    My neck/ centre piece wasn't thick enough, but I didn't want a quarter sawn /laminated neck, but rather a one piece Fender style neck, so I glued on an extra piece of Kiaat to make up the body thickness
    Wings were tapered top and bottom to the outside edges by sanding
    Cavities
    Fiesta Red likes this.
  4. Slowtwitch
    South Africa
    thinning out the headstock
    On my first neck I used a Japanese flush cut saw with a purpose made mitrebox (CNC to scribe the frets lines for perfect position). Did that again...
    It worked, however, the blade is slightly narrow, so I wanted to try a slightly wider blade. I decided to try this super cheap saw. It worked perfectly!!!
    crazydave911 likes this.
  5. Slowtwitch
    South Africa
    Trimmed the fretboard. Note the board is just held in place with locating pins and double-sided tape. Reason being I need access to router the accurate cavity for the P90 neck pup (when it arrives) so need to remove the board, but didn't want to stall progress. It worked a charm doing it this way
    Frets were good flush fit, gel superglue used on tang edge to glue in frets
    Side dots
    CraigB likes this.
  6. Slowtwitch
    South Africa
    home made fret bender approx 10" for a 12" radiused board. When pressing in frets when the board is not glued on, you need a backing board to support the thin piece of wood
    Board sitting flush with body for lower string hight and cleaner look - so I need to drop the bridge into the body to accommodate this
    (only a mock-up with locating pins holding the board)
    crazydave911, RiversQC and Jim_in_PA like this.
  7. Slowtwitch
    South Africa
    Radius transition done and starting to shape the neck
    checking alignment before doing my first Tele bridge cavity. Also dropped the Tele bridge approx 2.7mm into the body for good string hight.
    Neck cavity for P90.
    These few pics represents hours of work to get this done, from making accurate templates to final depth routing
    The hours spent paid off very well
  8. Slowtwitch
    South Africa
    Fretboard glued on, I used a bicycle inner tube to clamp the board along with other clamps (I don't own too many clamps) and have seen others use this method. It worked well, however, it does leave plenty glue residue afterwards which requires sanding flat. I shaped the neck by this stage and I was glad I didn't finish it before this step as it too some sanding to get off the glue residue
    The Firebird's a thin beast - one of the attractive points for me of this body shape IMG_20190804_182914.jpeg
    String-through holes done. This is my 2nd time I do this and came out good.
    First time to make a recessed fitting cover. Happy with the result
    The neck/ body transition wasn't easy to shape. I found it way more complicated than my first neck (bolt-on Fender style).
    But I'm happy with the end result.
    This pic also represents many hours
    Start with 1st sanding sealer
  9. Slowtwitch
    South Africa
    Pre-paint complete assemble. Single ply Scratch plate made and edges chamfered
    Made the Bone Nut (not shown) from my own blanks (refer to my first build) and shaped and slotted the nut
    Colour will be vintage green/ blue/ pearl. Difficult to show on camera
    At this stage, the guitar was assembled, electronics installed and frets levelled. Happy with how it sounds and plays
    All stripped again and time to finish this baby
    The Beech wood was stained using dye in Teak Oil. It worked okay, although it still doesn't come out even coloured. There are some darker spots which accepts the dye easier than other places.
    This is more evident on the back of the neck.
    Once I was happy with the colour, I switched to just Teak Oil to finish.
    Own logo's added. The Bird is my boy's creation since he will be playing this guitar way more than me, and to involve him in the build. To add the "reverse" theme, logo's were done upside down (facing the player) :)
    Poly clear coat - a rough job, but that's what sanding is for
    about 3-4 coats sanding sealer by brush sanded flat this weekend sprayed 2 coats Prime and there's still grain pore marks showing. The prime is basically the same particle thickness(?) as grain filler, so I stuck to prime.
    Here I'm doing spot filling by brush - this will be it - all pores are filled and I'm left with a pretty much perfect surface once sanded flat to start with colour
    Note that I've got no experience spraying besides Build No.1. So learning as much as I can and gaining confidence
    And this brings us to real time :)
    CraigB, PingGuo, Telemarx and 3 others like this.
  10. Deed_Poll
    Deed_Poll Tele-Meister
    Brighton, UK
    Wonderful job! I was loving the natural look, but something about that white paint job has just drawn attention to the sculptural details.
    The thin body is very nice, I also think it's a good fit for a Fender style headstock because you can sit it flat on a table unlike the original!
    Slowtwitch likes this.
  11. Slowtwitch
    South Africa
    Thank you sir, I agree the 2 tone wood does look good. However, there's too many imperfections I had to hide due to it being reclaimed wood, and also esp on the centre piece I had to add a little strip to make up the width.
    Also I'm very keen to try my hand at a gloss solid colour
  12. GPlo
    GPlo Tele-Meister
    Netherlands
    Very cool! Good job man you nailed it with this one.
  13. Slowtwitch
    South Africa
    Thx GPlo;)
    That Bass of yours.... maybe, just maybe a next project is looming also for a mate of mine :)
    GPlo likes this.
  14. Slowtwitch
    South Africa
    My first attempt at Nitrocellulose lacquer.
    Decided to do it vintage style, so a thin NC lacquer finish
    Here's the colour coat done. A vintage metallic type of blue/green, difficult to capture on camera
    That centre piece step has been a pain to work with, from routing the body, to round-overs, to prepping for painting...the whole process is more complicated
    CraigB, Jim_in_PA and PingGuo like this.
  15. Slowtwitch
    South Africa
    Clear coat done. Now the long wait for the lacquer to cure :rolleyes:
    One of the issues with this body shape is it doesn't fit a normal fender box style hard case :mad:. So while I wait for the paint to cure, I'm trying my hand at a hard case
    crazydave911 and bender66 like this.
  16. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    It’s gonna be heavy. Try a t style bass case or ex style guitar case.
  17. Slowtwitch
    South Africa
    I was very aware of the weight when planning, so I used 8mm MDF for the sides, 6mm ply for the tops and almost no wood for the interior. So far it seems okay
    Working with polystyrene is NOT recommended. It's fragile, is not as quick to shape as one thinks and it makes a massive mess!!!!:mad:
    jimilee likes this.
  18. Slowtwitch
    South Africa
    AAAAAAHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!:mad::mad::mad::mad::mad:
    It's been almost 4 weeks of curing the nitro lacquer, being patient,keeping myself from rushing to start final sanding and buffing.
    But felt it cured enough to start.
    It went well until...
    disaster - 3 spots close to the bottom edge, sanded through the colour :cry:
    (don't mind the unevenness on the edge it's the wet sanding)
  19. Slowtwitch
    South Africa
    Another 3 weeks in full sunlight later and the paint is still slightly tacky
    Now there's just one option :(
  20. Lostininverness
    Lostininverness Tele-Meister
    Christchurch, NZ
    That is gutting! I feel your pain, had lacquer cracking on two guitars when installing various screws. Have done one refin, still spinning my wheels on the other...
    Good luck with the rework
