2 lb 7 oz body = neck heavy?
Discussion in 'Tele Home Depot' started by brads, Jun 1, 2010.
  1. brads
    brads TDPRI Member
    Just received a chambered (no F-hole) Tele body that weighs 2 pounds 7 ounces unfinished.
    It feels almost weightless, and I'm worried it will make a neck-heavy guitar.
    It will have 2 humbuckers, standard Tele hardware, shorty 3-saddle ashtray bridge, and a typical (medium C) maple neck with rosewood board. Kluson-style tuners.
    I don't want to sink money into this (finishing, etc) if it's going to be neck heavy.
    Any thoughts?
    Thanks
  2. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    Are you going to use vintage tuners, or a set of locking tuners ?
    Sperzel lockers are pretty heavy as are square box ping as compared to all the kluson and kluson clone tuners.
  3. '56Teleman
    '56Teleman Tele-Afflicted
    Lindenhurst, IL
    I wouldn't worry about it, therefore, if you are worried about it pm me with a price.:)
  4. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    You could always add weights to the cavities if it were neck heavy. The Eastman El Rey can be a little neck heavy, and J Hale Guitars does just that to balance them better.
  5. robt57
    Portland, OR
    Example: One piney I did is 5.8 lb total weight. Under 3 lb body, and med V neck with WD Klusons and no tilt issue.
  6. jimdkc
    jimdkc Friend of Leo's Silver Supporter
    Independence, MO
    I'd tie helium balloons to the headstock... but...
    That's just me...
    Jim
  7. robt57
    Portland, OR
    How much does vintage helium cost, and is it as hard to get as R12 freon ??
  8. e-merlin
    e-merlin Doctor of Teleocity
    Garden City, KS
    One word answer:
    Yes.
    Detailed answer:
    My MIJ 69 Thinlinw was neck-heavy. It's something I expect with just about any Thinline...
  9. brads
    brads TDPRI Member
    Hmmm, a mixed bag of responses. I'm shocked.
    Too expensive to wing it.....I'll wait and see if more weigh in.
  10. Telenator
    Vermont
    I know you guys are going to think I'm crazy for what I'm about to say but, here it goes.
    Tele Thinlines, or and heavily chambered body for that matter will be more neck heavy than a solid body of the same weight.
    The reason for this is because the majority of the wood gets remove from the lower, larger end of the body pushing the weight bias more towards the neck than a solid body of the same exact weight.
    I have a Tele Thinline with a body weighing nearly 5 lbs and it's almost neck heavy!
    Personally I have never understood the fascination with ultra light bodies. A few do sound stellar but the majority of the ones I've played were awkward to hold and while they sounded good on a recording, just didn't cut it for me in a live band situation.
  11. K-Line
    K-Line Tele-Holic Vendor Member
    St. Louis, Missourah
    You should be ok. Total weight would be about 5-9 to 5-11 with hums. I have doen them this light before with no neck heavy-ness. I play a 6lbs 10OZ J-Bass and it borders neck heavy but a nice strap makes up for it. No guarantees though. Sell it to Greg, I can tell he is chomping at the bit for it.
  12. robt57
    Portland, OR
    I made two thinline bodies so far, not finished as of this writing.
    My Templates I got From Ron 6-7 years ago and are the thinline set he makes.
    The template has a square below the bridge area between the side chambers. On both I decided that wood need to stay there. But I guess you could route it and drill a hole through the strap peg and fill it with mercury for ballast if needed, ;)
    Or that depleted ukrainian stuff...
  13. boris bubbanov
    New Orleans, LA + in the
    Contact the above guy and get him to get you a good price on these "Stealth" tuners from Gotoh.
    They weigh half of what Gotoh splits weigh or around 2.5-3 ounces per set.
    Nobody has ordered a set yet and we wanna hear about 'em. :twisted:
    This could save the guitar. Keep the weight on, on anything from the bridge humbucker down and weight off from the neck humbucker up.
  14. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    I have wondered this before . If you were to move the rear strap button upwards from the typical location ( center line ) , wouldn't this move the center of gravity somewhat lower and slightly rearward from normal ? Could this help to counter the neck heavy thing ?
  15. boris bubbanov
    I think it challenged the strap button and guitars fell. Now that we have a detent mechanism on these straplocks, so I would definitely give rotating the button locations some consideration. Move the button on the bottom around to the left and towards the player's body and maybe also move the upper button towards the neck or even to the neck plate.
  16. cmatthes
    cmatthes Tele-Meister
    DC Metro
    If you don't take BB's idea, I've found that simply swapping out the tuner buttons to pearloid, ebony or some other lighter weight material eliminates any headstock dive instantly. I swapped the tuner buttons on a 3-hole Hamer DuoTone from the '90s and the whole instrument changed - for the better (and it was great before). Even with less mass at the headstock (the removal of about 2 lbs of chromed metal!), the whole thing vibrated like a mutha.
