2/3 confused about Strat pickups
Discussion in 'Just Pickups' started by Dan German, May 6, 2021.
  1. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    There is no such thing as a humbucking or noiseless pickup for Strat. Not in my world. :D
  2. Dan German
    Also on my radar…
    northernguitar likes this.
  3. Steve Holt
    Steve Holt Friend of Leo's
    Kansas
    RWRP means reverse wound reverse polarity. It's a reference to how one pickup is wound compared to another. There's no such thing as an RWRP pickup.
    Pickup A: wound clockwise with magnets charged North up
    Pickup B: wound counter-clockwise with magnets south up
    This is reverse wound reverse polarity. This is hum canceling. In the old days pickups were all wound the same direction with the same magnetism, and this caused them to him. To fix it you reverse the wind on the middle pickup so when the two pickups are on together you have RWRP. Either pickup on its own will sound however it will sound on its own. In phase or out of phase also means nothing if you only have one pickup selected.
    EDIT: I think I'm seeing the confusion. I never suggested using two "RWRP pickups" - my suggestion was that the OP use two pickups wound reverse from each other to get the hum canceling. So whereas your suggestion was to use a neck and bridge out of a set of RWRP pickups, my suggestion was to use either neck/middle or middle/bridge. Or just find any two ol' strat pickups that are wound opposite.
    mkdaws32 likes this.
  4. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    I just look at it this way - take a known good stock Strat, and drop the middle pickup, and rewire it for a 3-way switch, and rewire the middle pickup's tone pot to be for the bridge pickup.
    So, if dropping the middle pickup in an existing Strat is all that you're excluding, then what does that leave you with? Just the neck and bridge units from any given set.
    If having position 2 of the pickup selector (3-way) means you want hum canceling, only then might it complicate things a little. I've got too many 2 pickup guitars that either didn't offer this, or the two pickups that I chose by different vendors didn't allow for it, so I'm just not concerned with it.
    Anyway, that's my advice, FWIW. I actually do rewire my Strats as illustrated above.
  5. Rob DiStefano
    Rob DiStefano Doctor of Teleocity Vendor Member
    Swampland
    RWRP means reverse coil wire wind and reverse top magnetic polarity. Just reversing the leads of two similar pickups won't make them RWRP.
    mkdaws32 and beagle like this.
  6. Steve Holt
    Kansas
    And where exactly did I say that? I see you've highlighted my post red. I wasn't referring to flipping the wires, as I never said that. I said reverse the wind. As in "when you manufacture the pickup wind it the opposite of the other (reverse the wind)
  7. beagle
    beagle Friend of Leo's
    Yorkshire
    I well remember "the old days" and my Strats are still like that. :D
    I'm not confused about what they are or what they do. just by your original statement which makes no sense at all.
    as only the middle pickup of a set of three Strat pickups is RWRP.
  8. beagle
    Yorkshire
    Nor mine.
  9. Steve Holt
    Kansas
    "So I'd find two Strat pickups that are RWRP"
    Yes yes. I see where I lost you now. My wording wasn't clear. What I meant while trying to type on my phone was "find two strat pickups that are RWRP" from each other.
  10. beagle
    Yorkshire
    And that would have made sense. I still wouldn't bother though.
    Steve Holt likes this.
  11. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    A big +1 on this friendly and wise advice!!
    mkdaws32 and northernguitar like this.
  12. Danjabellza
    Danjabellza Friend of Leo's
    Pahrump, nv
    Middle and either of the others. That way if it is RWRP, you’re covered.
  13. Steve Holt
    Kansas
    And I would. A perfectly fine difference of opinion.
    beagle likes this.
  14. telemnemonics
    Hahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha!
    benderb9 likes this.
  15. Leonardocoate
    Leonardocoate Tele-Meister
    Ohio
    They are not all the same. You will need the middle for sure for hum cancelling. the bridge will have shorter leads and wound a bit hotter. I made a Duo Sonic with balanced output and RWRP and did not care for the tonal pallet. The guy that bought it loved it. He is mostly a rhythm player, if you want to cut through the mix with leads I would suggest the bridge and middle....you must choose, Obi Wan...have fun
  16. J. Bonkosky
    J. Bonkosky Tele-Holic Silver Supporter
    Seattle Washington
    What set are you looking at Dan? You could probably use whichever pickup you want in any position. It can’t be wrong if that is how you decide to set it up for you application.
    archetype and Steve Holt like this.
  17. Rob DiStefano
    Swampland
    You didn't mention polarity, which is a necessary half of the RWRP equation.
    Reverse the leads in a Strat pickup reverses the wind - it's one in the same.
    However, just reversing the leads won't make any single coil RWRP. You also need to flip the top magnetic polarity in order achieve an RWRP mode for one of two pickups.
    By themselves, wind direction and magnetic polarity for a single pickup guitar (i.e. - Esquire) have nothing to do with tone. Introducing another coil changes everything.
    archetype likes this.
  18. telemnemonics
    Strat pickups?
    Pick two!
    benderb9, RevBillyG and Dan German like this.
  19. Zepfan
    Horn Lake, MS
    I would choose the neck and middle pickup, or have the bridge and middle pickup next to each other in the bridge area(middle on a on/off toggle) and neck pickup in the neck position using a 3-way switch.
  20. telemnemonics
    I would look at what sort of sounds you want, or else state what Strat set you are choosing from.
    Do you want a classic stratty sound?
    Or a good bridge & neck sound from Strat shaped pickups?
    Bridge for Rock leads?
    Funk rhythm?
    Country Tele bridge sound?
    Gilmourish?
