2/3 confused about Strat pickups
Discussion in 'Just Pickups' started by Dan German, May 6, 2021.
  1. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    So, if I’m putting pickups intended for a Strat into a 2 pickup not-Strat, which two strat pickups do I get? Neck and Bridge? Middle and Bridge? Neck and Middle?
  2. Blue Bill
    DG, I think usually, they're all the same.
    Edit: Ummm, I just checked. Fralin sells them as specifically bridge, middle, or neck. Sooo, your guess is as good as mine. I suppose it depends on whether you like the B/M, B/N, or N/M combo sounds best.
    Steve Holt likes this.
  3. beagle
    beagle Friend of Leo's
    Yorkshire
    If the middle is RWRP, then use bridge and neck. If they're all the same it doesn't matter.
  4. Dan German
    You mean if it’s from a set of three where the middle is RWRP, get the bridge and neck from that set?
    JohnnyCrash and Deaf Eddie like this.
  5. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    Bridge and middle are usually hum cancelling. Strat pickups are usually higher output from neck to bridge. This may be important because some neck pickups pull on the strings. Choose wisely.
  6. Dan German
    Problem is, I don’t know which combo I like, ‘cuz I don’t do Strat. :D
    JohnnyCrash and Blue Bill like this.
  7. Steve Holt
    Steve Holt Friend of Leo's
    Kansas
    If it were me I'd still do RWRP because that's what I do on my teles.
    So I'd find two Strat pickups that are RWRP. They're all the same in how they're made. It's not like a Tele with two crazy different ones. The number of winds or resistance could be different across a set of 3, same with the type of magnets used. There are quite a few variables that would change the tone here and there.
    But say you bought a set of 3 and decided to flip them around its not like the bridge pickup used at the neck would sound like a bridge pickup.
    So I'd look for a neck and middle to try to get RWRP. Or just specify that to a pickup winder like @Bootstrap
    JunebugJones and jayhaknavy02 like this.
  8. beagle
    Yorkshire
    Close your eyes and pretend it's a Tele. :D
  9. Steve Holt
    Kansas
    I think it'll be neck/bridge no matter what combo you choose. Think telecaster.
    Dik Ellis and Dan German like this.
  10. Dan German
    My fall-back position is to call Bootstrap and let him decide for me. :D
  11. beagle
    Yorkshire
    Ask them what colour the guitar should be too... :p
    WalthamMoosical likes this.
  12. beagle
    Yorkshire
    That just the same as using two standard winds and limits choice to middle pickups only.
  13. NoTeleBob
    NoTeleBob Tele-Afflicted
    Southwestern, USA
    Just did this on a 2 pickup guitar. Strat Middle is usually same as the neck but RW. Bridge is usually wound hotter for the reduced volume inherent at the bridge. So use the Middle and the Bridge and you still have the hotter Bridge along with hum-canceling Middle.
    Maguchi, radiocaster, RhinoV and 6 others like this.
  14. Rob DiStefano
    Rob DiStefano Doctor of Teleocity Vendor Member
    Swampland
    It would be a good idea to think of the entire design and build of pickups desired, with regards to both the tone/output of a pair of single coils, as well as their position/orientation. All of these qualities run a spectrum that you would probably want to be sure will meet your requirements for the kind of music you wish to create.
  15. schmee
    I don't think it's huge which you do, but I would go with Neck and Bridge. Some strat sets are the same in neck- middle. Actually some are the same all 3!
  16. Dan German
    Excellent advice. I’m thinking in broad strokes at the moment. What it comes down to is whether I roll the dice and buy off the rack, or use my head and contact an actual trained professional. Of which you are one. :D
    mkdaws32 likes this.
  17. jim777
    jim777 Tele-Meister
    South New Jersey
    Depends on whether the "pickups designed for a Strat" were humbucking (or other 'noiseless' flavor) or single coil. There's literally so many options here..
  18. Steve Holt
    Kansas
    That doesn't make any sense to me.
  19. beagle
    Yorkshire
    Neither does using two RWRP pickups instead of two normal ones.
    RWRP is only used in the middle pickup to get hum cancelling when used with either of the normally wound neck or bridge pickups. The real choices in Strat sets are in the neck and bridge. pickup
  20. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Dik Ellis, mkdaws32 and Dan German like this.
