1st time Build , T-style Ulysses
Discussion in 'Tele Home Depot' started by Ulysses, Aug 28, 2014.
  1. Ulysses
    Ulysses TDPRI Member
    Dublin, IRE
    Thanks Jupiter and Glenn for making me sound mysterious (",)
    It was a happy accident with the backwards s , so I kept it.
    Dunno what's up with my profile giving 404 errors? -
    Just got an email from a moderator here at tdpri asking me to fix the backwards s, it's creating problems with my profile. Ah well, suppose I'll have to fix it.
  2. fretman_2
    fretman_2 Friend of Leo's
    Mobile, AL
    Beautiful build and your inlays look great! I used to do the wire inlay on muzzle loading pistols. I used brass to do that and had to anneal the brass to make it soft enough to inlay. Never thought about doing that on a guitar until now.
    Instead of cutting the design with a scapel, break up a hack saw into three or four pieces, then sharpen the end into tips of various widths. Then you draw the design and then tap a groove into the wood with the tips of the hacksaw piece. Then tap the inlay strips into the channel you created. That's how I was taught to do the inlay on the muzzle loading pistols.
    Here's what the hacksaw piece would look like...
    Here's a shot of how the wire inlay look in the wood...
    After the wire is annealed...it'll follow any curve you want to put on it..
  3. Ulysses
    Dublin, IRE
    Excellent advice fretman 2 and thanks for your kind words.
    I will definitely try that on the next build.
    The backwards 's' is gone guys. I had to change it - it was causing too many problems.
  4. tintag27
    tintag27 Tele-Afflicted Silver Supporter
    Old England
    Lovely work - ambitious and very tidy!
  5. Ulysses
    Dublin, IRE
    Thanks Tintag
    Yeah ambitious is right- "go big or go home". (",)
    I plan on building a lot more guitars so I wanted to try lots of techniques and get my mistakes behind me and learn from them so I can move on.
    Learning how to address and repair these mistakes is paramount for me.
  6. Ulysses
    Dublin, IRE
    ImageUploadedByTDPRI1410269043.361722.jpg the workshop needed a good clean toady. Now I'm getting stuck into cutting the template for the Ulysses logo. Using the piercing saw I'm cutting the letters out of an old plastic backplate. I will use these letters as my main template for cutting the MOP or abalone. I'll just stick the letters to the Shell with double sided tape and cut them out.
  7. Ulysses
    Dublin, IRE
    Plastic template done
  8. Ulysses
    Dublin, IRE
    It's gonna look something like this. But not black- it'll be MOP ImageUploadedByTDPRI1410274748.400603.jpg
  9. DrASATele
    North of Boston
    looking good, I did something similar, lots of thicknessing, sanding and body prep. Got a really good feel for working with routers. It's a good exercise if you're not completely familiar with the tool.
  10. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Beautiful work, Ulysses! The MOP inlay is a great design, and I dig the silver wire work as well.
  11. Ulysses
    Dublin, IRE
    Thanks guys
  12. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Great work, looks awesome. Really like the inlay work on the top.
  13. Ulysses
    Dublin, IRE
    Thanks Zepfan. I'm a Zepfan myself (",)
  14. Ulysses
    Dublin, IRE
    Using the plastic template stuck to the shell with double sided tape to cut the MOP with the piercing saw
  15. Ulysses
    Dublin, IRE
    Slow and steady.
    I switched back to just using a printed template. The plastic was moving ever so slightly.
  16. Ulysses
    Dublin, IRE
    Mother of pearl cut.
    I reckon it's gonna be tricky to inlay into the headstock!
  17. Engraver-60
    Engraver-60 Friend of Leo's
    Brentwood, TN
    Beautiful inlay you've made there. Looks classical and modern all in one. No doubt you'll inlay it just fine.
  18. Ulysses
    Dublin, IRE
    Thankyou Engraver (",)
  19. Ulysses
    Dublin, IRE
    Starting the inlay process with the dremel and scalpel
  20. Ulysses
    Dublin, IRE
    Almost ready for glue
