1st time Build , T-style Ulysses
Discussion in 'Tele Home Depot' started by Ulysses, Aug 28, 2014.
  1. Ulysses
    Ulysses TDPRI Member
    Dublin, IRE
    Two alder tops glued and flush trimmed using me new spiral bit alder top flush trim.jpg alder top flush trim 2.jpg
    telesunbath.jpg Sunbathing on the bonnet
    tele flush trim.jpg 2nd one
    spindle sander.jpg Could have used this sooner but hey its never too late to get a spindle sander
  2. Ulysses
    Dublin, IRE
    neck allignment.jpg Neck Alignment with a steel rule. Must get a laser
    Decided to see what it would look like to inlay the neck plate. Good practice on the dremel with stewmac attachment.
  3. Ulysses
    Dublin, IRE
    Neck pocket route - needs to go deeper
    snug as a bug
  4. Ulysses
    Dublin, IRE
    quick mockup with scratchplate vs's pickup ring. I'm liking the ring.
  5. Ulysses
    Dublin, IRE
    I got four litres of acetone from a hairdresser suppliers not far away. Will I ever use it all on binding alone? Are there other uses?
    binding channel routed.jpg binding channel routed (dremel with stewmac bit)
    Binding stuck on with acetone, little bit stretched with heatgun,
    mix up a batch of binding paste for the repair.
  6. Ulysses
    Dublin, IRE
    binding scraped.jpg Binding repair looks good after scraping and bridge lined up for Drilling
    string thru ferrules.jpg String Through Ferrules
    bridge route.jpg Bridge Pickup Route
  7. Ulysses
    Dublin, IRE
    Once I had the pickup routes done I couldn't resist a proper hardware mock up.
    mock up 2 no bc.jpg no Ashtray mockup 2 w bc.jpg Ashtray
  8. Ulysses
    Dublin, IRE
    Got some copper tape too for sheilding pickup cavities, some fine steel wool and blonde shellac flakes.
  9. Ulysses
    Dublin, IRE
    Break it back down again and start on the Sterling Silver Wire Inlay
    Cut the design with the scalpel
    Shaped the silver wire with a roundnose pliers and got the small hammer to Just tap it in.
    Wet the wood slightly before sanding so the grain grips the silver tighter.
  10. Ulysses
    Dublin, IRE
    Because the Mother of Pearl and Abalone inlay is in 16 separate pieces it was pretty tricky to get it arranged and inlaying was a slow process : cutting the wood with a dremel and finetuning with a scalpel, then filing the shell pieces to fit as snug as possible to each other - Thats why I didn't take any pics - too fiddly.
    sanding shell inlay.jpg But here it is being sanded.
  11. Ulysses
    Dublin, IRE
    sheilding 1.jpg While the Blonde Shellac flakes are dissolving in the methylated spirits I shield the pickup and control cavities with copper tape (including the holes I drilled from one cavity to the next by creating copper tubes with the tape). The tape will act as the ground for the bridge too.
    Shellac 1.jpg 1st coat French Polishing using Shellac build up in layers. The flames in the Alder Top are starting to show nicely.
    Shellac 2.jpg 2nd coat
    shellac 3.jpg 3rd coat
    shellac 4.jpg 4th coat
  12. Ulysses
    Dublin, IRE
    Shellac 5.jpg This was the 5th and last coat of Shellac hand french polished.....
    Then Disaster - When I test fit the bridge and control plate there where gaps of no shellac where the masking tape was too long. I tried to repair it but alas I had to sand back to bare wood.
    You live you learn. I also leave off the copper strapper for the bridge until I finish Redoing the shellac.:cry:
    shellac redo 1.jpg Here we go again
    shellac redo 2.jpg Its looking good - this second attempt is way better than the first
    shellac redo 3.jpg Near mirror finish . Happy again
  13. trev333
    Coolum Beach,Australia
    nice touch on the inlays and the wire scrolls.... :)
    lookin' good...
  14. Ulysses
    Dublin, IRE
    Carving a Heel tuck in the back with various files and scrapers.
    (you can see another bit of silver wire inlay too, matches the bottom)
    Tummy tuck.jpg Tummy tuck
    The carves really make the sapele grain look brilliant.
  15. Ulysses
    Dublin, IRE
    Thanks Trev333
  16. Ulysses
    Dublin, IRE
    So I french polished up the back and sides with shellac and put it all back together and soldered it up - no pics sorry.
    Another mockup.jpg another mockup 2.jpg another mockup 3.jpg another mockup 4.jpg
    So here we are up to date. I started getting the workshop ready at the end of April.
    Jobs left to do:
    • modify the neck near the body
    • change the headstock shape a bit
    • cut shell for the headstock logo
    • inlay headstock logo
    • french polish just the face of headstock
    • oil fretboard
    • reassemble
    • setup
    Get strap nuts.
    Then take better pics and do a vid
  17. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
    Really nice work on the inlays!
  18. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    This build is nice, and I like the inlays and all, but what I really wanna know is how'd you get that backwards "s" into your user name?? :eek:
    :lol:
  19. Glen Smith
    Glen Smith RIP
    I have no idea how he did it but when I try to view his public profile it doesn't work! I get a 404 error code.
  20. Ulysses
    Dublin, IRE
    Thanks Lisa, much appreciated.
