1st amp build, (One Stroke) Volume problem
Discussion in 'Shock Brother's DIY Amps' started by drew1d, Dec 31, 2018.
  1. drew1d
    drew1d Tele-Meister Silver Supporter
    Westchester NY
    Hello Amp builders,
    I am in my first amp build currently, and ran into a snag. It is basically a Two Stroke amp. But only one power tube, so a one stroke, as the kids call it these days.
    Turned on, No sparks, no smoke. For some reason it"s really quiet. The volume on the guitar almost cuts it when turned 3/4 on... The voicing switch only works in the Capacitor positions.
    But when I put a pedal in front of it. It roars. I mean, I have to turn the volume on the amp and pedal quite a bit, I'll say a "2" on each and it's louder than the amp alone turned all the way up.
    I figured, it has to be something wired with the input jack. Although I could be quite wrong, any thoughts where to look first?
    Much Thanks - Drew
    Pictures will be forethcoming. Happy New Year.
  2. printer2
    The input jack soldering or contacts.
  3. drew1d
    Westchester NY
    I have replaced the jack with the same results. Here's an aweful picture. Did I wire the input jack wrong twice?
  4. D'tar
    D'tar Friend of Leo's
    WNY
    I believe you have the jack terminals incorrect.
    That 68k is coming off the ground terminal
    What does the switch do? Switch bypass caps?
  5. drew1d
    Westchester NY
    Yes 68k ground terminal, I'll take a better picture tomorrow.
    Probably do have the terminals incorrect... The switch is supposed to be a voicing switch between that diminutive 25uf, nothing, behemoth 47uf capacitor.
    I heard on a youtube video of the person making the Twostroke, that the brand of jack he used was oriented in reverse of what the schematic would lend you to believe. I tried reversing the jack, (switching the terminals) but it made no noise after that.
  6. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    Input impedance too low?
    Could you provide a schematic and a layout?
    And some more/better pictures please.
  7. Tom Kamphuys
    The Netherlands
    Google came up with this:
    Is that correct?
  8. drew1d
    Westchester NY
    That's pretty close.
  9. brogh
    brogh Moderator Staff Member
    Teleland
    Admin Post
    there's also a flying resistor there to the right :eek:
  10. Tom Kamphuys
    The Netherlands
    I think that 68k should not go to ground. It should go to the grid.
  11. drew1d
    Westchester NY
    That sounds right. I did notice two things.
    1. Is the "2" lug grounded? everytime I aligator clip it to the ground I get no sound.
    2. I grounded "3" to the case next to it. Does that need to be attacked to the lug?
  12. drew1d
    Westchester NY
    That's my "discharge the lethal capacitors when I work on it" resistor.
    brogh likes this.
  13. brogh
    Teleland
    Admin Post
    i think it's the angle of the picture, there's a yellow wire that goes near there , seems to go to pin 3, but form the schematic it should go to pin 2 ?
  14. Tom Kamphuys
    The Netherlands
    You can have a permanent leak resistor, e.g. 220k
  15. drew1d
    Westchester NY
  16. Tom Kamphuys
    The Netherlands
    On the layout it is grounded near pin 2
    brogh likes this.
  17. brogh
    Teleland
    Admin Post
    Oh i see that's a far better picture ! :) went trough the schematic and can't see anything wrong, but i'm not so expert, other guys will chime in for sure :)
  18. corliss1
    Lansing, MI
    That layout drawing is just................bad.
    Why would you try grounding pin 3 of the 12ax7? That arrow says "to board" there as that needs to go to a resistor in order to get some bias voltage/current going.
    As it's drawn, the amp won't work, since as @D'tar mentioned, you're grounding the input. Get rid of that ground connection on pin 2 and switch how the input jack is wired. The 68K resistor needs to come from the hot side contact, not ground side.
    Electrical cord hot wire -> fuse side 1 > fuse side 2 > power switch > one side of PT.
    Neutral wire -> one side of PT.
    It's not drawn like that in either the layout or schematic, but that's how it should be done.
    If you compare the layout to the schematic that @Tom Kamphuys provided you'll see there is no ground on the input (pin2) either. I'd work off that schematic now that you have most of the parts in place since that layout diagram is just wrong.
  19. Tom Kamphuys
    The Netherlands
    It's the ground connection between the 68k and pin 2 (at least)
    It's not present on this layout:
  20. drew1d
    Westchester NY
    Oddly, it doesn't seem to matter when I "lift" the ground off. It's no difference in volume, a little more buzzy when not attached. I'm starting to think, because there is only one input jack, perhaps it's designed for low impedence feed. And the volume is just a natural result of that, and it's normal for what this amp is...
