1975 Silver Face Champ- snap, crackle and pop!
Discussion in 'Amp Tech Center' started by SanAnTex, Nov 18, 2017.
  1. keithb7
    keithb7 Poster Extraordinaire
    Western Canada
    One 6V6 was missing when current owner bought the Music Master amp. That tells me, good chance one tube shorted out. Then cap burst.
  2. SanAnTex
    SanAnTex TDPRI Member
    Hello everyone,
    I haven’t yet got the chance to work on this champ do to traveling for work. I really appreciate everyone’s help and look forward to working on this amp! I am about to order a cap and resistors online... do you think I should order any other components and replace them while I’m already “under the hood” of this amp? Thanks!
  3. SanAnTex
    What is the simplest way to drain the caps and remove the death cap? I would like to get the death cap out of there before I solder in the new resistor and cap to the 6v6. I have seen a video online where the guy just plugs the amp in and let the tubes get hot, then turns off the amp. I also have a multimeter to check the voltage. Thanks!
  4. peteb
    peteb Friend of Leo's
    Cascadia
    whats the simplest way to drain caps?
    Measure the voltage on the plus side of the filter caps, it will either be low volts, or it soon will be.
    whats the easiest way to remove the death cap?
    as you replace the two prong cord with the three prong cord, snip the cap out of the circuit.
