1970s DOD Electronic Phasor needs some TLC
Discussion in 'Burnt Fingers DIY Effects' started by lljsullins, Jul 23, 2019.
  1. lljsullins
    lljsullins TDPRI Member
    Dayton, Ohio
    My grandfather loved this pedal for many many years, he bought it new in Dayton of 78 I think. He used it in all of the clubs, he always said you can get a Lonnie Mack sound and a "creamy" Waylon sound. So now on to how it broke, he was replacing the battery and put it in backward I guess and it shorted out something, I really want to get this fixed for him, he's 77 and still gigging. It runs on a regular 9 volt, but I would like to use it with a wall adaptor if I could. Does anyone have a schematic or diagram for it or does anyone have one? Is it worth rebuilding? It's very very rare.. .
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    zippofan likes this.
  2. zippofan
    zippofan Tele-Afflicted
    Pennsylvania
    Wow! That's an oldie, and here I thought my DOD 201 was old. Unfortunately I don't have a schematic for it, though hopefully someone here or on one of the stomp box forums does.
    I cheated with my ca. 1978 DOD by replacing the guts with a General Guitar Gadgets Phase 45 circuit, which is pretty identical to the 201 except true bypass. Good luck!
  3. lljsullins
    Dayton, Ohio
    Hopefully, someone will help me out! Thanks man!
  4. jimdkc
    jimdkc Friend of Leo's Silver Supporter
    Independence, MO
    Nice pedal... especially with the grandfather story!
    Kinda hard to tell from the photos, but are there any obviously burnt components from the reverse voltage?
    Looks like it's been repaired at least a couple of times... lifted solder pads... wire jumpers... etc...
    Do you want to retain as much originality as possible? Or just return it to functionality?
    If it were mine, I'd be tempted to make a new circuit board for it.
    Should be pretty easy to wire in a power jack that disconnects the battery power when you plug it in.
  5. jimdkc
    Independence, MO
    Also... did you disconnect the wiring, or did somebody else? Do you know how everything wires back up?
  6. lljsullins
    Dayton, Ohio
    I have seen some pictures online about it and have tried to wire it back to specs with an old buddy of mine, actually an old teacher who used to do this stuff back at NASA. He said we could create a new board. Only thing is this board is kinda falling apart, I had it wired once where I got a signal through the pedal but the knobs would do nothing.
  7. lljsullins
    Dayton, Ohio
    The resistor on the back of the board (10k I believe) was burnt I replaced it to the best of my ability, this was before he got a decent soldering iron.
  8. lljsullins
    Dayton, Ohio
    I could get a breadboard and start doing some things...
  9. jimdkc
    Independence, MO
    Can you identify the transistors?
    Looks like it's probably a 6-stage op amp phaser circuit. These are pretty common and there are a lot of similar ones out there. The 2 chips are fairly common quad op amps. Six of the 8 op amps make up the 6 phaser stages. One of the other 2 op amps probably is used as an LFO (low frequency oscillator)... and the other is probably a gain stage or an input or output buffer.
    The transistors are probably FETs that are driven by the LFO. These FETs act as voltage controlled resistors which change the frequency response of an RC network connected to each op amp stage. This causes a phase shift of the signal going through the op amp. Run a bunch of op amps in a row like this (6 in this case), and you get the swirly, shifting, ethereal effect we know as "phaser".
  10. DeanEVO_Dude
    DeanEVO_Dude TDPRI Member
    Colorado Springs, CO
    The great thing about the "antique" circuits with discreet components like this is they are generally easier to repair. However, without a schematic or an extendensive knowledge of electronics engineering, there will be great difficulty In executing the repair.
    Old pedals are cool. Good luck, hope there is some info and assistance out there for you.
  11. lljsullins
    Dayton, Ohio
    Those six transistors I cannot read 5 out of the 6, but one says "singa" followed by some code.
  12. jimdkc
    Independence, MO
    They say "Singapore" on the top... Country of origin... anything readable on the front?
  13. jimdkc
    Independence, MO
    I would be surprised if the schematic of this circuit wasn't very similar to a MXR Phase 90... with a couple more stages added... Many MXR designs are re-worked DOD designs...
    Here's a very good analysis of the MXR Phase 90:
    https://www.electrosmash.com/mxr-phase90
  14. lljsullins
    Dayton, Ohio
    I'm stupid, forgive me ahaha. The code reads, "TIP5T-5460"
  15. jimdkc
    Independence, MO
    Don't feel bad, I'm sure I've made similar mistakes!
    Hmm... coming up blank on the JFETs... There is a 2N5460 that's a P-Channel JFET, but P-Channel devices aren't that common (although it is possible!). N-Channel JFETs are more likely. It might help to know the part number to know the pinout to figure out the circuit better, but that can be figured out by other means!
  16. radiocaster
    europe
    Check that diode if the battery was reversed. I once fried an effect by reversing the polarity of the adapter, unfortunately didn't keep the busted pedal when I moved way back in the day and I wish I did because it's not that cheap or easy to find anymore.
  17. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    if the electro caps are original, replace them
    socket the op amps
    socket the transistors
    wire it all back up
    this puts you in the best position to be able to test and swap parts out should those steps not remedy the issue.
  18. jimdkc
    Independence, MO
    Yeah. This is what I would do, too!
