Jasonpatrick
Is this normal for these. This buzzing sound. I feel it shouldn’t be. It’s had a full recap. CE can replacement. When I wire a 20uf cap in series with the Triangle node on the cap can it disappears until higher up on the reverb dial. If I remove the wire off the node and just through the 20 uf cap it’s back. So I don’t think it’s the can. Makes the noise without tank hooked up, with tank removed, turned around , upside down and ten blocks away. Jkjk.. I have looked and read about similar issues but the threads all just end before anyone is like hey , this is what I did. All voltages are well within spec. This guy is running GZ34 and has the AA764 tube chart. I know I know… I think some of it is my apartment but I wanted to see if any of you had any thoughts. Turn up your volume! I’m all ears!View media item 48257
