CodySorgenfrey
Hey everyone! I'm looking for some experienced members to help me sniff out what is going on with this amp, any help would be greatly appreciated, however I have tried a lot of different things already so please read the long story!
The long story not so short.
I got this amp on Ebay for a pretty good deal ($600). I knew from the pictures that it had been around the block, most of the amp was not original, but nonetheless, I've wanted one for a while and this is what I could afford. I am comfortable working on electronics, I've built a few guitar pedals from scratch and laid out some PCB boards, done some smart home things with ESP32 chips, etc. so I figured I can pour some money into fixing it up if I need to.
When the amp arrived, it had a broken 6L6GC from shipping and mostly original filter caps. So new pair of 6L6GCs from TAD and F&T filter caps ordered. Once those got here, I opened it up to balance and bias it as well as replace those electrolytics. With everything looking good I fired it up and it works and sounds good tone wise, but there was a lot of noise.
I have been on a mission for the last month literally 2-4 hours a day trying to fix this hum. I don't believe this level of noise is normal or acceptable, but I'll let you all be the judge of that. Here's what I know and what I've tried so far:
I've included a 100% accurate schematic of the amp as it is today. Here's a key to the schematic's color-coded info:
- What I know
- Noise is not affected by any controls.
- Noise is 100% gone if V4 is removed.
- Noise is ~75% gone if V3 is removed.
- Removing V1 or V2 changes the noise but doesn't reduce it.
- No extra noise chop sticking any components.
- What I've tried
- Bias was set using transformer shunt method.
- Inner 6L6 68% 20.3 Watts = .0453A * 448.0V
- Outer 6L6 67% 20.0 Watts = .0446A * 448.6V
- Humdinger pot on heater wires.
- Dropped heater voltage with resistors from 6.9VAC to 6.3VAC.
- Re-ran heater wires to be correctly in phase from tube to tube.
- Reflowed all solder joints.
- Reworked preamp grounding to use a bus and only connect at the input jacks.
- Reworked power amp grounding to use transformer lug instead of soldered to chassis.
- Replaced all tubes with brand new tubes.
- Complete disassembly and reassembly of the amp, testing and replacing out of spec components.
- This went so far that there is almost NO original components in this amp apart from some blue ajax molded caps and rectifier diodes.
- Ran under-board wires on top.
- Green OK indicates parts that came with the amp that tested good and were left. Everything without this Green OK label has been replaced with brand new quality parts.
- Orange measurements are what Fender claims at a given point.
- Purple measurements are what the amp is currently running.
- No input, all controls set to 0. 4 Ohm dummy load connected to speaker jack.
- High voltage ripple at standby switch. 5V/div, 5ms/div.
- Bias voltage ripple at pin 1 of balance pot. 1V/div, 5ms/div.
- Output jack. 20mV/div, 20ms/div.
- Output jack. 20mV/div, 5ms/div.
- Output jack. 20mV/div, 2ms/div.
- Pin 2 of V1. 20mV/div, 1ms/div. Rock solid
- Pin 7 of V1. 20mV/div, 1ms/div. Rock solid
- Pin 7 of V3. 20mV/div, 1ms/div. A little jittery
- Pin 2 of V4. 20mV/div, 20ms/div. Messy
- Pin 7 of V3. 5mV/div, 20ms/div. Messy
- Pin 7 of V4. 20mV/div, 20ms/div. Messy
- Pin 2 of V2. 20mV/div, 1ms/div. Rock solid
- Pin 7 of V2. 20mV/div, 1ms/div. Tiny bit of HF noise
- Overall circuit
- Back panel controls
- Bass Channel controls
- Bass Channel Circuit
- Bias & Rectifier board
- Doghouse
- Humdinger pot (I know this is close to touching the PT, I will use hot glue to secure once issues are resolved.)
- Normal Channel Controls
- Normal Channel & Power Amp circuit.
- Transformers
- All the dead soldiers
