I think I helped cause the failure by resting the chassis on a table with the tubes and filter cap can bearing all of the weight.
why would I do this?
because I saw Gerald Weber do it.
I take care to heat the chassis metal thoroughly by apply the chisel tip to that metal directly With the edge of tip contacting the tab. I do not sit the chisel tip on top of the tab. Otherwise..from my pint of view, the solder could flow quickly but not make a good joint with the chassis.
